can't pin images and documents folder to Quick access in file explorer
2022-11-24T10:54:18+00:00
Hi, i just uninstall Onedrive from pc and suddenly i can´t Pin Images and Documents folder to quick access, It give me the option but when you click don´t happen anything. Any solution???
DaveM121 934.2K Reputation points Independent Advisor
2022-11-24T11:29:01+00:00
Hi Maria,
I am Dave, I will help you with this.
Your Quick Access folder is probably corrupt, the best option is to delete the content of Quick Access, and then re-pin the folders you need there.
Click your Start Button, then just type cmd and on the resulting menu, right click Command Prompt and select 'Run as Administrator'
Paste this command into Command Prompt and press Enter:
del /F /Q %APPDATA%\Microsoft\Windows\Recent\*
del /F /Q %APPDATA%\Microsoft\Windows\Recent\AutomaticDestinations\*
del /F /Q %APPDATA%\Microsoft\Windows\Recent\CustomDestinations\*
Then, close Command Prompt and restart (not shut down) your PC.
50 additional answers
    2023-05-21T22:54:58+00:00
    This worked amazingly well, Dave! I've tried so many solutions available on the web without any success or luck. I came across your post, followed your instructions and was so pleased with the result that I had to post this reply. Thank you for this very helpful advice.
    2023-05-31T15:28:00+00:00
    looking for this fix for 3 months. Thanks so much !!! Same for me as many others, disconnecting from one drive caused lots of issues but this helped me fix the links.
    2023-06-07T15:15:40+00:00
    I'll try this when I get home, but I wanted to note that I also think this is an issue when disconnecting from OneDrive. I just set up a brand new computer, upgraded to Windows11, but disconnected OneDrive. The Quick Access bar had everything pinned except Documents and I couldn't add it.
    2023-06-10T16:37:16+00:00
    Should this fix work for Windows 10?
