can't pin images and documents folder to Quick access in file explorer
2022-11-24T10:54:18+00:00
Hi, i just uninstall Onedrive from pc and suddenly i can´t Pin Images and Documents folder to quick access, It give me the option but when you click don´t happen anything. Any solution???
DaveM121 934.2K Reputation points Independent Advisor
2022-11-24T11:29:01+00:00
Hi Maria,
I am Dave, I will help you with this.
Your Quick Access folder is probably corrupt, the best option is to delete the content of Quick Access, and then re-pin the folders you need there.
Click your Start Button, then just type cmd and on the resulting menu, right click Command Prompt and select 'Run as Administrator'
Paste this command into Command Prompt and press Enter:
del /F /Q %APPDATA%\Microsoft\Windows\Recent\*
del /F /Q %APPDATA%\Microsoft\Windows\Recent\AutomaticDestinations\*
del /F /Q %APPDATA%\Microsoft\Windows\Recent\CustomDestinations\*
Then, close Command Prompt and restart (not shut down) your PC.
50 additional answers
    2023-04-26T02:19:52+00:00
    Thanks, It works....
    2023-04-29T21:58:42+00:00
    Thank you for this help article! Once I uninstalled Onedrive (it's a gaming rig for games, period) none of the quick links worked. This fixed the issue!
    2023-05-08T02:29:15+00:00
    Only the 1st del cmd worked the others said
    is not recognized as an internal or external command,
    operable program or batch file.
    2023-05-11T14:38:33+00:00
    Thanks Dave, This worked.
    I still don't understand why Microsoft makes it hard to stop using Onedrive 🤦‍♂️.
