Could not update to 22h2 due to 0x800701b1 and 0xC1900101 error. Then I managed to update and boot fails, 0xc0000098 errror. What do I do?
2022-11-26T16:43:05+00:00
Well, this.
If I try to install the update after a while pc restarts and restores old version
Ramesh 181.6K Reputation points Volunteer Moderator
2022-11-27T16:03:13+00:00
Sacha,
Let's try deleting the erroneous boot entries which are pointing to a non-existent device.
The statutory warning applies! Before modifying the boot configuration, please backup your system image (the OS and boot partitions) to an external hard drive using Macrium Reflect Free edition.
From Admin Command Prompt, run:
  • bcdedit /export c:\boot_config_backup.bcd
  • bcdedit /delete {9649d88d-4b28-11ed-8001-6d7368757261}
  • bcdedit /delete {4069d4e4-2920-11ed-be4c-a85e45d0a878}
Then, run these commands and post the output here:
  • bcdedit /enum All
  • bcdedit /enum All -v
69 additional answers
    2022-11-27T17:29:27+00:00
    Sorry to interrupt, but I think it might be time for an attachment of your Disk Management window, with it expanded so we can read the partition descriptions.
    The reason I suggest this is because of the current situation being investigated and the line below in your log. I do not understand why the EFI system partition is so small, but it may not have room to copy over info it needs. Since that partition is normally 100 MB, did you make adjustments to the size?
    Detected 53 MB free (out of 85 MB total) on [\?\GLOBALROOT\Device\HarddiskVolume3\
    2022-11-27T18:09:27+00:00
    How can I make an USb setup disk?
    2022-11-27T18:10:41+00:00
    I did not mess with the boot partition, I would have no idea how to do so :D
  4. Deleted
