Could not update to 22h2 due to 0x800701b1 and 0xC1900101 error. Then I managed to update and boot fails, 0xc0000098 errror. What do I do?
2022-11-26T16:43:05+00:00
Well, this.
If I try to install the update after a while pc restarts and restores old version
Ramesh 181.6K Reputation points Volunteer Moderator
2022-11-27T16:03:13+00:00
Sacha,
Let's try deleting the erroneous boot entries which are pointing to a non-existent device.
The statutory warning applies! Before modifying the boot configuration, please backup your system image (the OS and boot partitions) to an external hard drive using Macrium Reflect Free edition.
From Admin Command Prompt, run:
  • bcdedit /export c:\boot_config_backup.bcd
  • bcdedit /delete {9649d88d-4b28-11ed-8001-6d7368757261}
  • bcdedit /delete {4069d4e4-2920-11ed-be4c-a85e45d0a878}
Then, run these commands and post the output here:
  • bcdedit /enum All
  • bcdedit /enum All -v
69 additional answers
    2022-11-27T00:13:16+00:00
    Latest bios yes
    I ran the troubleshooter before trying install, shall I do it again?
  2. Igor Leyko 112.4K Reputation points Independent Advisor
    2022-11-27T00:17:49+00:00
    Please share both setup log files mentioned in the link.
    Sorry, my answer will be late.
    2022-11-27T09:30:55+00:00
    I could not find those two files in windir/panther :(
    Anyway Windows Update is not trying to have me update to 22h2 anymore, so I can't test the troubleshooting
    2022-11-27T14:32:26+00:00
    I even tried to manually install 22h2 with the installation manager, but I get a "windows could not be installed" message. Same with ISO
