Could not update to 22h2 due to 0x800701b1 and 0xC1900101 error. Then I managed to update and boot fails, 0xc0000098 errror. What do I do?
2022-11-26T16:43:05+00:00
Well, this.
If I try to install the update after a while pc restarts and restores old version
Ramesh 181.6K Reputation points Volunteer Moderator
2022-11-27T16:03:13+00:00
Sacha,
Let's try deleting the erroneous boot entries which are pointing to a non-existent device.
The statutory warning applies! Before modifying the boot configuration, please backup your system image (the OS and boot partitions) to an external hard drive using Macrium Reflect Free edition.
From Admin Command Prompt, run:
  • bcdedit /export c:\boot_config_backup.bcd
  • bcdedit /delete {9649d88d-4b28-11ed-8001-6d7368757261}
  • bcdedit /delete {4069d4e4-2920-11ed-be4c-a85e45d0a878}
Then, run these commands and post the output here:
  • bcdedit /enum All
  • bcdedit /enum All -v
69 additional answers
  1. Ramesh 181.6K Reputation points Volunteer Moderator
    2022-11-28T18:06:51+00:00
    Pls take your time. As Windows loads fine, I think rebuilding the BCD is not a priority as of now.
  2. Igor Leyko 112.4K Reputation points Independent Advisor
    2022-11-28T18:31:54+00:00
    I'm sorry but zip file is empty.
    Please check log file for faulty driver name.
    2022-11-28T18:46:06+00:00
    It does load fine, but I have to go through that contraption of going in recovery mode first, which is kinda annoying :D
    2022-11-28T18:47:51+00:00
    I'm sorry mate,
    https://easyupload.io/t3g530
    Try now
