Could not update to 22h2 due to 0x800701b1 and 0xC1900101 error. Then I managed to update and boot fails, 0xc0000098 errror. What do I do?
2022-11-26T16:43:05+00:00
Well, this.
If I try to install the update after a while pc restarts and restores old version
Ramesh 181.6K Reputation points Volunteer Moderator
2022-11-27T16:03:13+00:00
Sacha,
Let's try deleting the erroneous boot entries which are pointing to a non-existent device.
The statutory warning applies! Before modifying the boot configuration, please backup your system image (the OS and boot partitions) to an external hard drive using Macrium Reflect Free edition.
From Admin Command Prompt, run:
  • bcdedit /export c:\boot_config_backup.bcd
  • bcdedit /delete {9649d88d-4b28-11ed-8001-6d7368757261}
  • bcdedit /delete {4069d4e4-2920-11ed-be4c-a85e45d0a878}
Then, run these commands and post the output here:
  • bcdedit /enum All
  • bcdedit /enum All -v
69 additional answers
    2022-11-28T12:26:57+00:00
    Ok, how do I do that?
    Oh, I forgot
    "But without a system image backup, the procedure shouldn't be attempted."
    You mean like a clone right? I tried to make an image backup with that app you suggested, but it only made some xml file of a few gigabytes, so maybe I'm missing something
    2022-11-28T13:32:51+00:00
    Ok I tried to do that with AOMEi partition assistant and it would not let me, it needed to reboot in a Windows PE environment but due to the error we're dealing with it could not.
  3. Ramesh 181.6K Reputation points Volunteer Moderator
    2022-11-28T14:31:41+00:00
    About backing up Windows and boot partitions, pls see this page and this. It creates one or more images with file extension .mrimg.
    To run Chkdsk on the EFI boot partition, run:
    • Diskpart
    • sel vol 4
    • assign letter=y:
    • exit
    Then, run:
    • robocopy Y:\EFI E:\Boot_files /MIR
    • chkdsk y: /r
    2022-11-28T17:01:10+00:00
    Ok, do I have to do it via the external usb boot as usual?
