How to change volume bar from middle bottom to top left on the screen
2022-11-07T16:56:31+00:00
Hi, usually on my screen's display, when I pressed the volume button on the keyboard, the volume bar will show on my screen at the top left. However, I accidentally pressed a lot of buttons, and the volume bar change from top left of the screen to the middle bottom of screen.
How do I change it back to the top left of screen? Thank you.
    2024-01-30T12:44:22+00:00
    I have this icon Windows 11 !!!
    2024-02-08T13:04:35+00:00
    Another needless DEprovement from Microsoft in their pursuit to be more like Apple, but without any semblance of the design sensibilities or thought about how it might affect their user's workflow. If I had any choice at all for an OS for my work PC, I would leave MS in the dust as fast as I can manage.
    Anyhow, thanks for making me click on the new volume bar and blasting out my eardrums a dozen times by now. Hate this company with a passion. Every new release is a pain.
    2024-02-09T14:39:20+00:00
    Your ears are welcome! Seriously though, I live in fear of any kind of IT "upgrade" you never know how it is going to leave the device operating.
    2024-02-09T15:11:54+00:00
    Good idea March 202 Patch Windows 11 Pro
    2024-04-03T18:56:33+00:00
    did anyone find a solution to this?
    I have given feedback and upvoted (windows+F) but seems nothing is being done? Such a small thing could easily be implemented
