How to change volume bar from middle bottom to top left on the screen
2022-11-07T16:56:31+00:00
Hi, usually on my screen's display, when I pressed the volume button on the keyboard, the volume bar will show on my screen at the top left. However, I accidentally pressed a lot of buttons, and the volume bar change from top left of the screen to the middle bottom of screen.
How do I change it back to the top left of screen? Thank you.
    2024-01-07T16:50:00+00:00
    How to restore the old volume bar like in Windows 10 through the registry system in Windows 11 Pro 23H2 ??
    When will the patch be released to fix this ??
    https://ithardware.pl/aktualnosci/menu_start_znow_bedzie_swietne_szef_windowsa_wkurzony_na_obecne_rozwiazania-30974.html
    "The Start Menu will be great again." The head of Windows is angry at current solutions ....
    2024-01-29T13:31:03+00:00
    The latest update just put the volume indicator on the bottom middle of the screen and made it super tiny!
    Please fix this, it's not a good feature.
    2024-01-29T16:10:11+00:00
    The best icon Volume Bar
    Use Windows 11
    Add Windows 11 Pro and Home
    February 2024 ----->> Change !!
    2024-01-30T12:01:56+00:00
    I have no idea what you're trying to say here.
    2024-01-30T12:43:06+00:00
    Microsoft add icon bar volume Windows 10 in Windows 11 Pro...
