How to change volume bar from middle bottom to top left on the screen
2022-11-07T16:56:31+00:00
Hi, usually on my screen's display, when I pressed the volume button on the keyboard, the volume bar will show on my screen at the top left. However, I accidentally pressed a lot of buttons, and the volume bar change from top left of the screen to the middle bottom of screen.
How do I change it back to the top left of screen? Thank you.
    2024-04-03T19:57:53+00:00
    This can be changed Patch in April 2024 !!
    2024-04-07T17:08:26+00:00
    HideVolumeOSD works great for W11 22H2 and 23H2. After installing, move icon from hidden to the taskbar, then right click icon >settings>show volume in system tray (and change font size if desired). I got it here: http://wordpress.venturi.de/?p=379
    2024-04-07T17:09:51+00:00
    HideVolumeOSD works great for W11 22H2 and 23H2. After installing, move icon from hidden to the taskbar, then right click icon >settings>show volume in system tray (and change font size if desired) I got it here: http://wordpress.venturi.de/?p=379
    2024-04-07T17:28:51+00:00
    No working Windows 11
    24H2
  5. Deleted
