No option to open Device and Printers in control panel in Windows 11 22h2
Reported
2022-10-06T16:29:13+00:00
In previous versions of windows 11 and windows 10, I was able to access the devices and printers options from control panel instead of settings. Now the devices and printers from control panel opens the settings, which lack some options, especially the option to turn on or off handsfree telephony for Bluetooth devices. Is there anyway to access this option in windows 11 22h2?
2022-10-06T16:38:35+00:00
Hi there,
In Windows 11 22H2 and higher, the old Devices and Printers interface can still be accessed by running the following command from the Run dialog.
  • shell:::{A8A91A66-3A7D-4424-8D24-04E180695C7A}
For other methods to open the classic Devices and Printers applet, see:
Optionally, you can add "Devices and Printers (Classic)" to the Control Panel.
Download devices-and-printers-classic-cpl.reg and apply the REG file.
You'll see the following option in the Control Panel.
46 additional answers
    2024-11-19T17:21:59+00:00
    Well, well, well! The LAST answer is the simplest one. I found this myself by accident also!
