Asus Tuf Gaming F15 Wi-fi problem
2021-11-30T13:01:42+00:00
Hello there, My Wi-Fi adapter has gone completely crazy and do not know what's going on.
I'm using the Asus Tuf Gaming F15 Laptop and the intel Wi-Fi 6 ax201 160mhz, I use it for graphic design work and gaming which everything fine until the Wi-Fi disconnect and the icon disappear. It happen again and again and I tried everything to get it back on but keep showing error like code 10 and 43. However, Here are some possibility that causes the Wi-Fi disable:
  1. When the battery is low, I plug the charger for my laptop and after a second or minute, the Wi-Fi started disappear. I check on the device manager and it show me the error. But I disable and enable it and the Wi-Fi is fine but it might happen again.
  2. I think graphics might be the problem for Wi-Fi to disconnect because when I start the game on my laptop and about a minute, the Wi-Fi disconnect and show the error on device manager. This happen many time when you start the gaming apps.
  3. Similar thing happen on 2 other problem I just describe, I notice something that while I was doing my thing on my laptop, my screen goes glitch jump while i moving my mouse to direction (hard to describe) and start hearing buzz noise about a second. I don't know what it is and how it happen? I think is the frame that causes for Wi-Fi error but I can't be sure about it.
That's all the problem I just discover. This happen every time when start my computer and hard to fix it.
I hope you got this message, Thanks
Eric Truong
    2022-09-23T22:06:08+00:00
    I am Computer Service Consultant been more than 30 years experiences. I have more than several my customer who frustrate with Wireless been troubleshoot since it was worked before Windows 10 update.
    I found the wireless driver been changed to incorrect against wireless hardware brand device. I think Microsoft are responsible these test hardware device first nor Microsoft did un-authorized without request to Brand company will test and approved by their certificate driver of brand model.
    Did Microsoft have hundred times tested the different brand hardware and device will pass test before RELEASE to public get update driver ? I know their answer No.
    I don't think MS didn't done a test properly against customer or business were frustrate again. I believe so. customer would fedup and expense their services repair cost against blame Microsoft.
    How do I put "LOCKED DRIVER" without Windows Update Driver ? Because driver is perfect operator without any unauthorised update driver.
    2022-09-24T13:43:57+00:00
    I totally agree with you.
    2022-10-25T15:01:55+00:00
    Have you found any solution to this problem?
    Im facing the exact same problem
    2022-11-25T14:40:54+00:00
    Exactly the same problem like your. If someone got solution pls help. Thank you.
    2022-11-25T14:59:17+00:00
    i had this problem a time ago, it used to happen most of the time when I unplug the charger cable and use my laptop on battery, this problem never happened again after i deleted the "Armoury Crate" from my laptop, i hope this will help.
