Thank you so much for the solution provided.
Asus Tuf Gaming F15 Wi-fi problem
Hello there, My Wi-Fi adapter has gone completely crazy and do not know what's going on.
I'm using the Asus Tuf Gaming F15 Laptop and the intel Wi-Fi 6 ax201 160mhz, I use it for graphic design work and gaming which everything fine until the Wi-Fi disconnect and the icon disappear. It happen again and again and I tried everything to get it back on but keep showing error like code 10 and 43. However, Here are some possibility that causes the Wi-Fi disable:
- When the battery is low, I plug the charger for my laptop and after a second or minute, the Wi-Fi started disappear. I check on the device manager and it show me the error. But I disable and enable it and the Wi-Fi is fine but it might happen again.
- I think graphics might be the problem for Wi-Fi to disconnect because when I start the game on my laptop and about a minute, the Wi-Fi disconnect and show the error on device manager. This happen many time when you start the gaming apps.
- Similar thing happen on 2 other problem I just describe, I notice something that while I was doing my thing on my laptop, my screen goes glitch jump while i moving my mouse to direction (hard to describe) and start hearing buzz noise about a second. I don't know what it is and how it happen? I think is the frame that causes for Wi-Fi error but I can't be sure about it.
That's all the problem I just discover. This happen every time when start my computer and hard to fix it.
I hope you got this message, Thanks
Eric Truong
2022-07-16T23:08:34+00:00 -
2022-08-04T10:06:22+00:00 I don't know how everyone is going fixinig this problem.
I gave up in the end a purchansed another Wi-Fi Adaptor card.
Took, 5 minutres to open up and change over the card, and cleaning the fans while I had the back open.
Have used it costantly other the next 2 days and it's working beautifully, no Blue Screens or any other issues.
Yes, the laptop is under warranty, but as I have no baackup computer and ASUS wanted the laptop for 7 to 10 business days. Can not do without it for that many days.
Regards, Mark
2022-08-04T10:45:35+00:00 the main issue is with the driver,In my case it is happened after windows update. there is two solution what i did first was reinstalled windows with the asus image file located in the unlabeled volume of this laptop.then again i made the mistake of updating windows, after searching on the community i found a link to diver by a user and it worked for me. i recommend to pause windows upfdate
2022-08-26T14:09:45+00:00 Looks like the last BIOS update solves an issue
2022-09-02T23:09:52+00:00 Did it solve your problem?
