When was the last time you could install WIndows on the PC? Was Linux installed yet?
What has changed since you could install WIndows exactly?
** I am resposting this from Asus help site as I still haven't found a solution** Hello. First off I'm new! I built a computer from scratch last year. I have the Asus x570 gaming motherboard. I installed windows 11 a few weeks ago and it has been running fine. Last week, it green screened and now I can't get it to boot to windows no matter how I try. I'm at a loss, I keep thinking there is something I can do other than send my motherboard back, but no one has any advise that has worked yet. I've included a video that, is the problem. Has anyone had issues? Or suggestions. Ive now disconnected all drives but my main m2 drive, I have windows bootable in there. I've tried booting legacy. And uefi. I just don't know what else to do! Things I've tried...
No matter what I try, it just sits on the window square screen.
ALSO it will let me boot just fine to a Linux USB without an issue. video
No. Linux was not installed when this issue appeared. The night before this issue started my computer froze, I turned it off for the night. I turned it on the next morning, it was fine for about an hour...and then it reboot itself. and I wasn't able to ever come back to windows the right way. One time I was able to get to the recovery screen.. that was after I took out and put back in my NVME drive and upgraded the bios... i tried to reinstall windows in the recovery screen and it came back with errors..and froze and restarted..and since then, I have not been able to ever get back into windows. That was Oct 8th, was the last time.
here is a link to the video I made for all the bios rundown...
Did you try booting the Windows media after making the Settings changes I suggested?
If it won't boot with SSD connected, disconnect the SSD and try booting it.
Yes ...so I'm booting it with the CD I made. And it says "press any let to boot with CD" and when I do ...again it has a pause like it's trying to load and then goes to windows splash screen
What CD? This is the first I've heard of a this. It needs to be a DVD, not a CD. It also needs to be double layer and written by Windows Image Burner from the ISO queued up by Media Creation Tool.
