Hi PCR ....
Here is the latest as per your instructions. Thank you for your reply once again. Most appreciated.
The disk management screen shot is at the end of the cmd information.
In your last reply after the instructions, you said: the following, but I do not know what this means or what needs to be done next if anything. Can you please explain / clarify further ?
"(2) The Firmware Boot Manager in the BCD is a window to the BIOS Boot menu screen. Yours isn't set normally for a UEFI installation.,,
identifier {fwbootmgr}
displayorder
{c4337ee6-11b0-11ec-ab4f-806e6f6e6963} <<<Direct boot to EFI
{c4337ee7-11b0-11ec-ab4f-806e6f6e6963} <<<Direct to a hard drive
{c4337ee8-11b0-11ec-ab4f-806e6f6e6963} <<<Also direct boot to EFI
{c4337ee3-11b0-11ec-ab4f-806e6f6e6963} <<<Boot to CD/DVD drive
timeout 0
It should instead boot to the Windows Boot Manager ({bootmgr}). You do have one in the BCD, but it is missing its device & path values. There is a lot amiss in your BCD. I'm thinking we should generate a new one altogether instead of tinkering with this one.
cmd details follow here:
Microsoft Windows [Version 10.0.19042.1237]
(c) Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>diskpart
Microsoft DiskPart version 10.0.19041.964
Copyright (C) Microsoft Corporation.
On computer: GARRY-INTEL1
DISKPART> select disk 0
Disk 0 is now the selected disk.
DISKPART> select part 4
Partition 4 is now the selected partition.
DISKPART> detail part
Partition 4
Type : de94bba4-06d1-4d40-a16a-bfd50179d6ac
Hidden : Yes
Required: No
Attrib : 0000000000000000
Offset in Bytes: 999546683392
Volume ### Ltr Label Fs Type Size Status Info
* Volume 4 G NTFS Partition 627 MB Healthy Hidden
DISKPART> remove Letter=G
DiskPart successfully removed the drive letter or mount point.
DISKPART> GPT ATTRIBUTES=0x8000000000000001
DiskPart successfully assigned the attributes to the selected GPT partition.
Partition 4
Hidden : Yes
Required: Yes
Attrib : 0X8000000000000001
* Volume 4 NTFS Partition 627 MB Healthy Hidden
DISKPART> exit
and the view in file explorer now looks like this and note that there is no longer a drive G showing. I will now rename L: to G: so that my backups work again.
Once again, thank you very much for your help so far. Nice to know that there is knowledgeable community help available, and that there are those like yourself willing to help. so grateful.
Cheers!
Garry
