Onedrive seems to have created its own drive G partition and moved my previous drive G partition to drive L
2021-10-01T22:00:28+00:00
One drive has messed up my partitions in that I had a drive G called WorkArea (G) that has the one drive folders to sync on it, along with all other files and folders on it. Somehow my G drive WorkArea (G) (partition) was reallocated to drive L WorkArea (L), and a separate partition G now called Local Disk (G). has appeared in the original drive G's place. (not talking about drive Mapping here).
In windows explorer I see the following screen shot
whereas in disk management, G does NOT show up at all and I cannot change WorkArea (L) back to G.
Drive L does show up in windows explorer, but is not in the screen shot. .
and trying to re-assign WorkArea to G I cannot, as it is unavailable.
how do I fix this?
I tried to uninstall OneDrive, and reboot but nothing changed.
Can someone please help me fix this as my backup plans are set for G as what is in WorkArea L and now backup of G only shows OneDrive files, that were not part of the backup plan to begin with.
Thanks for any help you can offer. Much appreciated.
Garry G
    2021-10-13T03:25:50+00:00
    G:drive does look like a Recovery partition. Let's see whether it has its WinRE.wim...
    (a) Type CMD into Search, & click "Run as Administrator".
    (b) Enter the following commands...
    DIR G:\ /a /s <<<List all folders & files on G:
    ReagentC /Info <<<Show whether it is the Recovery partition officially
    Something caused the letter to be grabbed away from the drive which had OneDrive. The OneDrive partition then took L: for its letter. A Recovery partition shouldn't have a letter, but it should show up in Disk Management with a designation like your EFI got (which is disk 0, partition 2). Let's see what the partitions look like in DiskPart. Enter the following commands into that same Command Prompt...
    DiskPart <<<Enter DiskPart
    List Vol <<<List the Volumes
    List Disk <<<List the Disks
    Select Disk 1 <<<Focus on Disk 1
    List Part <<<List the partition numbers on Disk 1
    == For each partition number (x) enter the following two commands ==
    Select Part x <<<Focus on partition x
    Detail Part <<<Show partition info
    == After that, exit DiskPart ==
    Exit <<<Exit DiskPart
    Use Ctrl-A & Ctrl-C to copy it all, then paste it to us for examination.
    2021-10-13T23:25:27+00:00
    >> Something caused the letter to be grabbed away from the drive which had OneDrive. The OneDrive partition then took L: for its letter. <<
    Hi PCR...
    Thanks for your reply here much appreciated. Before we take this much further, I think I need to clarify what has happened, as that might change your recommendations. (which I will follow below.)
    1. I started with Onedrive having been a folder structure on my G drive that was syncing with one drive. My G drive was a logical partition with many file folders on it on my HDD.
    2. Onedrive changed something similar to Google's latest changes I believe, where, what was one Onedrive and syncing to the folder structure on my G drive, and changed the G drive drive letter from G to L (thus messing up my daily backup plan), and created what looks to be a NEW G; drive in windows explorer, but is NOT a partition in Disk management. there is no G partition in disk management.
    Yet it appears to be a partition or Drive in explorer.
    There were some Onedrive files (or shortcuts in G that should not have been there since they are still in a folder on the current L drive.
    I cannot get rid of G, so that I can change drive L back to drive G as it was before Onedrive messed it up. I do not understand what happened or why.
    I will start with visuals of the situation....
    Here is what disk management is showing:
    WorkArea(L:) on the right side of disk 1 was G until Onedrive change it to L
    Note there is no drive G in here.
    currently in work area L there is what was my designated Onedrive folder to sync to originally before things changed in Onedrive and it was working as expected. Onedrive was pointing here. Was originally on G (WorkArea but is now on L WorkArea).
    Lookin at windows explorer now here is what is there. Note G is designated as Local Disk (G:)
    In G above before I attempted to unlink OneDrive in my Onedrive account there were other files in G that indicated they were OneDrive's, and I copied out to another folder just in case... but now those files have been resolved down to the following;
    clicking on this folder shows the folder is empty so whatever files were there were deleted when OneDrive was unlinked and uninstalled.
    OK, so now to follow your instructions above:
    But notice in the disk management screenshot above, the second partition showing is boxed in green and shows as a logical drive. Yet in the DiskPart it shows up as the fourth partition. I don't know if this is significant or not.
    :\WINDOWS\system32>DIR G:\ /a/s
    Volume in drive G has no label.
    Volume Serial Number is E31E-4FF1
    Directory of G:\
    10/01/2021 02:16 PM <DIR> $RECYCLE.BIN
    08/30/2021 03:51 PM 0 .txt
    10/12/2021 05:20 PM <DIR> Recovery
    10/09/2021 08:52 PM <DIR> System Volume Information
               1 File(s)              0 bytes
    Directory of G:$RECYCLE.BIN
    10/01/2021 02:16 PM <DIR> .
    10/01/2021 02:16 PM <DIR> ..
    09/09/2021 03:03 AM <DIR> S-1-5-18
    10/01/2021 02:16 PM <DIR> S-1-5-21-3451534017-3744945240-3527661392-1061
               0 File(s)              0 bytes
    Directory of G:$RECYCLE.BIN\S-1-5-18
    09/09/2021 03:03 AM <DIR> .
    09/09/2021 03:03 AM <DIR> ..
    09/09/2021 03:03 AM 129 desktop.ini
               1 File(s)            129 bytes
    Directory of G:$RECYCLE.BIN\S-1-5-21-3451534017-3744945240-3527661392-1061
    10/01/2021 02:16 PM 129 desktop.ini
               1 File(s)            129 bytes
    Directory of G:\Recovery
    10/12/2021 05:20 PM <DIR> .
    10/12/2021 05:20 PM <DIR> ..
    10/12/2021 05:20 PM <DIR> WindowsRE
               0 File(s)              0 bytes
    Directory of G:\Recovery\WindowsRE
    12/07/2019 02:08 AM 3,170,304 boot.sdi
    12/05/2020 02:40 PM 467,659,897 Winre.wim
               2 File(s)    470,830,201 bytes
     Total Files Listed:
               5 File(s)    470,830,459 bytes
              16 Dir(s)     169,254,912 bytes free
    C:\WINDOWS\system32>ReagentC /Info
    Windows Recovery Environment (Windows RE) and system reset configuration
    Information:
    Windows RE status:         Disabled
    Windows RE location:
    Boot Configuration Data (BCD) identifier: 201ca33c-3744-11eb-ab08-a9da93046d68
    Recovery image location:
    Recovery image index:      0
    Custom image location:
    Custom image index:        0
    REAGENTC.EXE: Operation Successful.
    C:\WINDOWS\system32>diskPart
    Microsoft DiskPart version 10.0.19041.964
    Copyright (C) Microsoft Corporation.
    On computer: GARRY-INTEL1
    DISKPART> list Vol
    Volume ### Ltr Label Fs Type Size Status Info
    Volume 0 Y DVD-ROM 0 B No Media
    Volume 1 Z DVD-ROM 0 B No Media
    Volume 2 C Local Disk NTFS Partition 930 GB Healthy Boot
    Volume 3 FAT32 Partition 100 MB Healthy System
    Volume 4 G NTFS Partition 627 MB Healthy Hidden
    Volume 5 D Application NTFS Partition 58 GB Healthy
    Volume 6 E Data1 NTFS Partition 429 GB Healthy
    Volume 7 F Data2 NTFS Partition 488 GB Healthy
    Volume 8 L WorkArea1 NTFS Partition 886 GB Healthy
    Volume 9 I Removable 0 B No Media
    Volume 10 J Removable 0 B No Media
    Volume 11 K Removable 0 B No Media
    Volume 12 M Removable 0 B No Media
    DISKPART> List Disk
    Disk ### Status Size Free Dyn Gpt
    Disk 0 Online 931 GB 0 B *
    Disk 1 Online 1863 GB 1024 KB
    Disk 2 No Media 0 B 0 B
    Disk 3 No Media 0 B 0 B
    Disk 4 No Media 0 B 0 B
    Disk 5 No Media 0 B 0 B
    DISKPART> select disk 1
    Disk 1 is now the selected disk.
    DISKPART> select part 1
    Partition 1 is now the selected partition.
    DISKPART> detail part
    Partition 1
    Type : 07
    Hidden: No
    Active: No
    Offset in Bytes: 1048576
    * Volume 5 D Application NTFS Partition 58 GB Healthy
    DISKPART> select part 2
    Partition 2 is now the selected partition.
    Partition 2
    Type : 07
    Hidden: No
    Active: No
    Offset in Bytes: 524289048576
    * Volume 7 F Data2 NTFS Partition 488 GB Healthy
    DISKPART> select part 3
    Partition 3 is now the selected partition.
    DISKPART> detail part 3
    The arguments specified for this command are not valid.
    For more information on the command type: HELP DETAIL PARTITION
    Partition 3
    Type : 07
    Hidden: No
    Active: No
    Offset in Bytes: 1048577048576
    * Volume 8 L WorkArea1 NTFS Partition 886 GB Healthy
    DISKPART> select part 4
    Partition 4 is now the selected partition.
    Partition 4
    Type : 07
    Hidden: No
    Active: No
    Offset in Bytes: 62916657152
    * Volume 6 E Data1 NTFS Partition 429 GB Healthy
    DISKPART> select part 5
    The specified partition is not valid.
    Please select a valid partition.
    There is no partition selected.
    DISKPART> exit
    Leaving DiskPart...
    Note I tried for a Part 5 to see what would happen and as expected there is no partition 5.
    Thanks very much for your instructions and help. I do very much appreciate it.
    Cheers!
    Garry
    2021-10-14T01:08:42+00:00
    (1) Oops, I wanted Disk 0. Please repeat DiskPart for Disk 0...?...
    Select Disk 0 <<<Focus on Disk 0
    List Part <<<List the partition numbers on Disk 0
    BCDEdit /Enum All <<<And let's see the BCD
    (2) I see G:drive is there in your List Vol...
      Volume 4  **G**  NTFS Partition  627 MB  Healthy Hidden
    It is the 627 MB partition appearing after C: in your Disk Management (DM). But it looks wrong in DM. It should look like mine...
    With or without a letter on my Recovery partition, I get that designation (disk 0 partition 4) in the top pane. And the bottom is as circled. Neither the letter nor the label I put on it (WinRE 21H1) show up in the bottom pane. (I'm sure they used to in prior versions.) They only show in DiskPart & File Explorer now. And here is what mine looks like in DiskPart...
    DISKPART> Detail Part
    Partition 4
    Type : de94bba4-06d1-4d40-a16a-bfd50179d6ac
    Hidden : Yes
    Required: Yes
    Attrib : 0X8000000000000001
    Offset in Bytes: 999313944576
    * Volume 3 WinRE 21H1 NTFS Partition 847 MB Healthy Hidden
    We want to get the letter off yours, but most important will be the Type code & possibly the Attrib. I suspect your Type code has gone bad & must be made to match mine. Hopefully, that will get your Disk Management to match mine. Then, we need to activate the Recovery partition either using ReagentC (which may not work) or by putting the code for it directly into the BCD.
    2021-10-15T14:20:10+00:00
    Hi PCR ..
    thanks again for your help. the following is the information you requested for partition 0.
    Hope this enable you to tell me how to fix tis.
    Much appreciated,
    Garry
    Microsoft Windows [Version 10.0.19042.1237]
    (c) Microsoft Corporation. All rights reserved.
    C:\WINDOWS\system32>diskpart
    DISKPART> list Vol
    DISKPART> list Disk
    DISKPART> select disk 0
    Disk 0 is now the selected disk.
    DISKPART> list part
    Partition ### Type Size Offset
    Partition 1 Reserved 128 MB 17 KB
    Partition 2 System 100 MB 129 MB
    Partition 3 Primary 930 GB 229 MB
    Partition 4 Recovery 627 MB 930 GB
    Partition 1
    Type : e3c9e316-0b5c-4db8-817d-f92df00215ae
    Hidden : Yes
    Required: No
    Attrib : 0000000000000000
    Offset in Bytes: 17408
    There is no volume associated with this partition.
    DISKPART> select part2
    DISK - Shift the focus to a disk. For example, SELECT DISK.
    PARTITION - Shift the focus to a partition. For example, SELECT PARTITION.
    VOLUME - Shift the focus to a volume. For example, SELECT VOLUME.
    VDISK - Shift the focus to a virtual disk. For example, SELECT VDISK.
    DISKPART> detail part 2
    DISKPART> list part
    * Partition 1 Reserved 128 MB 17 KB
    Partition 2
    Type : c12a7328-f81f-11d2-ba4b-00a0c93ec93b
    Hidden : Yes
    Required: No
    Offset in Bytes: 135266304
    * Volume 3 FAT32 Partition 100 MB Healthy System
    DISKPART> list part
    * Partition 2 System 100 MB 129 MB
    Partition 3
    Type : ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
    Hidden : No
    Required: No
    Offset in Bytes: 240123904
    * Volume 2 C Local Disk NTFS Partition 930 GB Healthy Boot
    DISKPART> list part
    * Partition 3 Primary 930 GB 229 MB
    Partition 4
    Hidden : Yes
    Required: No
    Offset in Bytes: 999546683392
    * Volume 4 G NTFS Partition 627 MB Healthy Hidden
    DISKPART> exit
    Leaving DiskPart...
    C:\WINDOWS\system32>BCDEdit /Enum All
    Firmware Boot Manager
    identifier {fwbootmgr}
    displayorder {c4337ee6-11b0-11ec-ab4f-806e6f6e6963}
                        {c4337ee7-11b0-11ec-ab4f-806e6f6e6963}
                        {c4337ee8-11b0-11ec-ab4f-806e6f6e6963}
                        {c4337ee3-11b0-11ec-ab4f-806e6f6e6963}
    timeout 0
    Windows Boot Manager
    identifier {bootmgr}
    device unknown
    description Windows Boot Manager
    locale en-US
    inherit {globalsettings}
    default {current}
    resumeobject {00699258-3744-11eb-956e-efd836ee9db2}
    displayorder {current}
    toolsdisplayorder {memdiag}
    timeout 30
    Firmware Application (101fffff)
    identifier {c4337ee3-11b0-11ec-ab4f-806e6f6e6963}
    description CD/DVD Drive
    identifier {c4337ee6-11b0-11ec-ab4f-806e6f6e6963}
    device partition=\Device\HarddiskVolume2
    path \EFI\MICROSOFT\BOOT\BOOTMGFW.EFI
    identifier {c4337ee7-11b0-11ec-ab4f-806e6f6e6963}
    description Hard Drive
    identifier {c4337ee8-11b0-11ec-ab4f-806e6f6e6963}
    path \EFI\Microsoft\Boot\bootmgfw.efi
    Windows Boot Loader
    identifier {current}
    device partition=C:
    path \WINDOWS\system32\winload.efi
    description Windows 10
    locale en-US
    inherit {bootloadersettings}
    recoverysequence {201ca33c-3744-11eb-ab08-a9da93046d68}
    displaymessageoverride Recovery
    recoveryenabled Yes
    allowedinmemorysettings 0x15000075
    osdevice partition=C:
    systemroot \WINDOWS
    nx OptIn
    bootmenupolicy Standard
    Windows Boot Loader
    identifier {201ca33c-3744-11eb-ab08-a9da93046d68}
    device partition=G:
    path \windows\system32\winload.efi
    description Windows Recovery Environment
    locale en-US
    displaymessage Recovery
    osdevice partition=G:
    systemroot \windows
    nx OptIn
    winpe Yes
    Windows Boot Loader
    identifier {becbfbbb-74c1-11e3-a193-d3e592cc6be4}
    device partition=C:
    systemroot \windows
    nx OptIn
    winpe Yes
    Resume from Hibernate
    identifier {00699258-3744-11eb-956e-efd836ee9db2}
    device partition=C:
    path \WINDOWS\system32\winresume.efi
    description Windows Resume Application
    locale en-US
    inherit {resumeloadersettings}
    recoveryenabled Yes
    filedevice partition=C:
    filepath \hiberfil.sys
    debugoptionenabled No
    Windows Memory Tester
    identifier {memdiag}
    device unknown
    path \boot\memtest.exe
    description Windows Memory Diagnostic
    locale en-US
    badmemoryaccess Yes
    EMS Settings
    identifier {emssettings}
    bootems No
    Debugger Settings
    identifier {dbgsettings}
    debugtype Serial
    debugport 1
    baudrate 115200
    RAM Defects
    identifier {badmemory}
    Global Settings
    identifier {globalsettings}
    inherit {dbgsettings}
                        {emssettings}
                        {badmemory}
    Boot Loader Settings
    identifier {bootloadersettings}
                        {hypervisorsettings}
    Hypervisor Settings
    identifier {hypervisorsettings}
    hypervisordebugtype Serial
    hypervisordebugport 1
    hypervisorbaudrate 115200
    Resume Loader Settings
    identifier {resumeloadersettings}
    Device options
    identifier {201ca33d-3744-11eb-ab08-a9da93046d68}
    ramdisksdidevice partition=G:
    ramdisksdipath \Recovery\WindowsRE\boot.sdi
    Device options
    identifier {becbfbbc-74c1-11e3-a193-d3e592cc6be4}
    description Ramdisk Options
    ramdisksdidevice partition=C:
    ramdisksdipath \Recovery\becbfbbb-74c1-11e3-a193-d3e592cc6be4\boot.sdi
    2021-10-15T23:13:13+00:00
    (1) Here are your partitions on Disk 0...
    Partition 1 Reserved 128 MB 17 KB <<<MSR (Microsoft Reserved)
    Partition 2 System 100 MB 129 MB <<<EFI System partition
    Partition 3 Primary 930 GB 229 MB <<<Windows (C:)
    Partition 4 Recovery 627 MB 930 GB <<<Recovery partition
    The MSR doesn't show up in Disk Management by design. I'd rather it immediately precede Windows, but that's OK as is. The details of each is fine except for Recovery...
    Partition 4
    Hidden : Yes
    Required: No
    The type code (GUID) is good. Required should be "yes". Let's remove the letter & set the Attrib properly...
    Select Part 4 <<<Focus on partition 4 (Recovery)
    Detail Part <<<Show the old details
    Remove Letter=G <<<Remove letter G
    GPT ATTRIBUTES=0x8000000000000001 <<<Set Attrib
    Detail Part <<<Show the new details
    Notes:
    0x8000000000000000 Prevents the partition from having a drive
                                      letter automatically assigned.
    0x0000000000000001 Marks the partition as required.
    After that, G: will no longer show up in File Explorer. Let's see a new picture of Disk Management to see whether it looks better for Recovery in the upper & lower panes.
    (2) The Firmware Boot Manager in the BCD is a window to the BIOS Boot menu screen. Yours isn't set normally for a UEFI installation.,,
    displayorder
    {c4337ee6-11b0-11ec-ab4f-806e6f6e6963} <<<Direct boot to EFI
    {c4337ee7-11b0-11ec-ab4f-806e6f6e6963} <<<Direct to a hard drive
    {c4337ee8-11b0-11ec-ab4f-806e6f6e6963} <<<Also direct boot to EFI
    {c4337ee3-11b0-11ec-ab4f-806e6f6e6963} <<<Boot to CD/DVD drive
    timeout 0
    It should instead boot to the Windows Boot Manager ({bootmgr}). You do have one in the BCD, but it is missing its device & path values. There is a lot amiss in your BCD. I'm thinking we should generate a new one altogether instead of tinkering with this one.
    (a) Have you ever been in BIOS & altered the Boot Menu?
    (b) Is BIOS set to boot in UEFI or Legacy mode? The missing {bootmgr} under Displayorder (above) has me wondering.
