Hi Lse. I'm Greg, 10 years awarded Windows MVP, specializing in Installation, Performance, Troubleshooting and Activation, here to help you.
Here are steps to recover from failed Updates or Version Update install which cause Windows to fail to start or function. If any steps won't work then report back and move on to the next. At least one step will always work, leading up to if necessary doing an automated Reset or a gold standard Clean Install:
- Try whichever method works in this tutorial link to get into Advanced Startup Options to run System Restore or Uninstall Updates button, or if this is a version update Go Back to Old Version: https://www.tenforums.com/tutorials/2294-advanc....
Easiest is to restart or force shutdown the PC twice to force it into Repair Mode.
If you are able to access System Restore or Go Back and it fails, skip to step 3.
- Go to another PC to create bootable media following instructions toward the bottom of the download page here: http://windows.microsoft.com/en-us/windows-10/m.... Uncheck the box for recommended settings to use only those for the target PC. The bootable media has it's own set of files and drivers that may work better if the ones in Windows are corrupted, it is also the only method that doesn't require the password if you're stuck on that.
Boot media by powering up the PC while pressing the BIOS Boot Menu Key: https://www.sysnative.com/forums/hardware-tutor...
You may need to enter BIOS/UEFI Setup to turn off Fast Boot if it won't allow the Boot Menu key to interrupt starting Windows: https://www.mydigitallife.net/comprehensive-lis...
Choose UEFI version of media if offered, browse to second screen to Repair Your Computer link.
- Choose Advanced Troubleshoot options to run System Restore, Uninstall Updates button, or if this was a version Update choose More Options to Go Back to Old Version.
If it rolls back then you can hide the Windows Updates and Version Upgrade responsible until they mature by installing and running immediately the Hide Updates tool:
If this fails try a Startup Repair, or go back to Troubleshoot Options on the previous screen to Reset your PC which will save your files while reinstalling Windows.
You could also at this point boot the Acronic rescue media to restore the image you have.
- If that fails you can use the booted media created in Step 2 to Clean Install the latest version which should get you past all difficulties as it has hundreds of thousands of others who have followed the steps in this link and never come back to report another problem: http://answers.microsoft.com/en-us/windows/wiki... The link compiles the best possible install of Windows 10 that will stay that way as long as you stick with the tools and methods given.
There is a step to rescue files from the same bootable media: http://answers.microsoft.com/en-us/windows/wiki...
Make sure during the booted install to follow the illustrated steps to delete all partitions down to Unallocated Space to get it cleanest, then click Next to let it auto-create the needed partitions, format them and begin install - this makes it foolproof.
The media provided for the Clean Install is latest and normally the problems go away with the Clean Install, however if they don't you can find earlier version media to use here: https://tb.rg-adguard.net/public.php
Burn to DVD using Windows Image Burner or create bootable 8+gb flash stick installer using one of the methods here: https://www.tenforums.com/tutorials/2376-create...
Then once you're back in Windows 10, you can block the problem Update using one of these methods: https://www.tenforums.com/tutorials/8280-hide-s...
For Version Updates the most stable method to install is using the media as shown in these steps for overcoming Version Upgrade problems: http://answers.microsoft.com/en-us/windows/wiki...
All possible ways to control Updates now are here:
https://www.techrepublic.com/article/how-to-con...
I hope this helps. Feel free to ask back any questions and let us know how it goes. I will keep working with you until it's resolved.
______________________________________________
