Wifi problems
2021-06-03T12:12:14+00:00
I need some real help as HP support doesn’t seem to know how to help and maybe it’s a windows problem.
I purchased an HP laptop 15s-eq2017AU about 2 weeks ago and I have wifi problems I cant fix.
 I am trying to keep it short. My internet disconnects or being connected without Internet etc. Sometimes it works well with normal speed, then all of a sudden I have a speed drop down to 4mbps/02mbps and shortly after I drop out of internet. Only my new laptop has this issue, all other devices, about 10, have no problems.
I have moved all my devices to 2.4Ghz except this laptop which is on 5Ghz. This made my laptop stable but I cannot connect to 2.4Ghz without problems.
Troubleshoot says various things like Wifi doesn’t have a valid IP configuration, network cable is not properly plugged in or may be broken, Problem with wireless adapter or access point or default gateway not available. Sometimes it fixes IP issue, sometimes it doesn’t. Troubleshoot will always reset my network driver. I did 2 network resets manually too without success.
Yesterday I did a troubleshoot and I had that blue screen: System Thread Exception not handled, what failed: rtwlane6.sys which is my network adapter I am pretty sure. After I restarted it was deactivated. Whats that about?
I tried static IP, DNS, uninstalled driver numerous times, Power is set to best performance, did the prompt commands reset, release, renew flush, ran the HP hardware diagnostics which all passed.
I was researching more and found an old post in this community that made me think.
The Wifi icon in the lower bar and it doesn’t matter if its 2.4 or 5Ghz, sometimes it says Local area connection which then is Public, sometimes it says my normal network (netgear) which then is private. When 2.4Ghz is on local network, speed drops and it doesn’t take long to disconnect then. But 5G runs still fast and fine.
I also have sometimes that laptop icon instead of Wifi icon with 5Ghz and I am still connected. When I am disconnected I have that round ball thingy. Laptop is not wired.
As said as long as I am on 5Ghz all is fine despite the icon change and network status. I doubt its my router settings since all other devices are fine. I did try another modem today and had around 5 devices on each network and my laptop didnt work well on both networks.
My laptop is very fresh, haven’t installed many 3^rd^ party apps, only whats app, inSSIDer Wifi analyzer which both were installed because of the issue and Bitdefender Internet security. Issue was before I installed it. I do have Office 2007 but thats not a 3rd party I assume.
Any thoughts would be fantastic. Thanks for your time.
Silke
    2021-06-05T01:49:28+00:00
    Disable Receive Segment Coalescing (RSC)
    Open PowerShell as admin and run:
    Get-NetAdapter
    Disable-NetAdapterRsc -Name "wifi card name from the previous command"
    For example:
    Disable-NetAdapterRsc -Name WiFi
    Disable-NetAdapterRsc -Name "Wi-Fi"
    If I wanted to enable it, instead of Disable I just write Enable-....?
    I just wait until you answer, its itching me to try it but I better wait for you. :)
    2021-06-05T02:15:50+00:00
    Hi ThornySeeker6 -
    Yes you can try that steps, but I suggest that you create a restore point before you perform that steps so that in case you encounter an error or some complications, you can reverse the changes by going to the restore point that you created.
    https://support.microsoft.com/en-us/windows/cre...
    Thank you,
    Jerico T.
    2021-06-05T02:58:41+00:00
    Hi and thanks for reply.
    Did a restore point, now I am having issues getting the command right.
    Get-NetAdapter tells me:
    Interface Description: Realtek RTL8852AE WiFi 6
    I tried various things like
    Disable-NetAdapterRsc-Realtek-RTL8852AE-WiFi-6
    with or without dash, with or without Realtek etc. its always error. What the command, please?
    2021-06-05T04:09:49+00:00
    Never mind, I did it and it didnt work.
    All day 2.4GHz cant find an access point.
  5. franco d'esaro 25,096 Reputation points Volunteer Moderator
    2021-06-05T08:24:02+00:00
    Hi ThornySeeker6 ,
    1. Temporarily uninstall Bitdefender via its proprietary removal software and try again.
    2. If you haven't done so yet, turn off your router, turn it back on after a few minutes and try again.
    3. are the laptop and router close or far apart? Are the 2 devices located on the same floor of the house?
    4. Try placing the laptop near the router, does the problem still persist?
    5. Try to temporarily turn off all other devices, stay connected to your network only with your laptop, check if it works properly or if the problem still persists.
    6. If you have a smartphone, temporarily configure the mobile hotspot, then connect to the hotspot and see if the problem still occurs.
