Wifi problems
2021-06-03T12:12:14+00:00
I need some real help as HP support doesn’t seem to know how to help and maybe it’s a windows problem.
I purchased an HP laptop 15s-eq2017AU about 2 weeks ago and I have wifi problems I cant fix.
 I am trying to keep it short. My internet disconnects or being connected without Internet etc. Sometimes it works well with normal speed, then all of a sudden I have a speed drop down to 4mbps/02mbps and shortly after I drop out of internet. Only my new laptop has this issue, all other devices, about 10, have no problems.
I have moved all my devices to 2.4Ghz except this laptop which is on 5Ghz. This made my laptop stable but I cannot connect to 2.4Ghz without problems.
Troubleshoot says various things like Wifi doesn’t have a valid IP configuration, network cable is not properly plugged in or may be broken, Problem with wireless adapter or access point or default gateway not available. Sometimes it fixes IP issue, sometimes it doesn’t. Troubleshoot will always reset my network driver. I did 2 network resets manually too without success.
Yesterday I did a troubleshoot and I had that blue screen: System Thread Exception not handled, what failed: rtwlane6.sys which is my network adapter I am pretty sure. After I restarted it was deactivated. Whats that about?
I tried static IP, DNS, uninstalled driver numerous times, Power is set to best performance, did the prompt commands reset, release, renew flush, ran the HP hardware diagnostics which all passed.
I was researching more and found an old post in this community that made me think.
The Wifi icon in the lower bar and it doesn’t matter if its 2.4 or 5Ghz, sometimes it says Local area connection which then is Public, sometimes it says my normal network (netgear) which then is private. When 2.4Ghz is on local network, speed drops and it doesn’t take long to disconnect then. But 5G runs still fast and fine.
I also have sometimes that laptop icon instead of Wifi icon with 5Ghz and I am still connected. When I am disconnected I have that round ball thingy. Laptop is not wired.
As said as long as I am on 5Ghz all is fine despite the icon change and network status. I doubt its my router settings since all other devices are fine. I did try another modem today and had around 5 devices on each network and my laptop didnt work well on both networks.
My laptop is very fresh, haven’t installed many 3^rd^ party apps, only whats app, inSSIDer Wifi analyzer which both were installed because of the issue and Bitdefender Internet security. Issue was before I installed it. I do have Office 2007 but thats not a 3rd party I assume.
Any thoughts would be fantastic. Thanks for your time.
Silke
    2021-06-04T09:18:05+00:00
    Quick question, I am downloading and just to double check, please see picture. I simply clicked that big blue button Download tool now, thats correct, right? I am downloading on a USB drive is that ok? The other option ISO said I will have to burn on a dvd later which my laptop cant do.
    The other link says "in-place upgrade", you mentioned repair install. Same thing?
    Btw, I really like how well you explain so I actually understand what you want me to test and why.
    The command prompt scans were all fine, no corruption detected and no integrity violation.
    Cheers
    2021-06-04T10:10:20+00:00
    Hi ThornySeeker6 -
    Yes, that's correct, just click the blue button. Yes, In-place Repair/Upgrade is also the same, you don't have yo put it on a USB drive or DVD, save the ISO file on your computer then run it then follow the video tutorial.
    Thank you,
    Jerico T.
    2021-06-04T12:51:15+00:00
    Well, so far so good but will have to wait and see again.
    It wasnt that simple first to install. I did the USB install, I should have waited for your reply.
    First I started from BIOS but it said the upgrade option isnt available if you start your computer using Windows installation media.
    I ended up just going on my D Drive and clicked setup and it worked.
    I did uninstall my Bitdefender as suggested in your video.
    My 2.4GHz initially was super slow but it didn't disconnect. I did all windows updates and for now I am at max speed. I will observe tomorrow when more devices are connected again.
    Thanks heaps, even if it doesn't work because its actually the hardware or so, your help is great.
    Cheers
    2021-06-04T13:32:24+00:00
    Hi ThornySeeker6 -
    Thank you for your patience and I'm glad that your computer is now working fine.
    Have a great day!
    Regards,
    Jerico T.
    2021-06-05T01:33:59+00:00
    Hi Jerico,
    Unfortunately problem is not solved at all. After reading a bit more, what are the chances that "Disable Receive Segment Coalescing (RSC)" could fix it? And if so, how would I do that?
    They had terrible slow speed but they were sure they didnt have a hardware problem as they were able to fix it for a short while.
    Its a bit different in my case I think; my network driver gets constantly reset during troubleshoot or HP online assistance without fixing anything, IP issues and so on. And again, its only 2.4Ghz and that is only because I have only this laptop connected to 5GHz, if I hade more on this network, Id have the same issues here too.
    So frustrating this laptop.
    Cheers
