That's fantastic news!!
Did he replace it with the same card?
And more importantly, did you offer the technician a cuppa? ;) 😄
Cheers
I need some real help as HP support doesn’t seem to know how to help and maybe it’s a windows problem.
I purchased an HP laptop 15s-eq2017AU about 2 weeks ago and I have wifi problems I cant fix.
I am trying to keep it short. My internet disconnects or being connected without Internet etc. Sometimes it works well with normal speed, then all of a sudden I have a speed drop down to 4mbps/02mbps and shortly after I drop out of internet. Only my new laptop has this issue, all other devices, about 10, have no problems.
I have moved all my devices to 2.4Ghz except this laptop which is on 5Ghz. This made my laptop stable but I cannot connect to 2.4Ghz without problems.
Troubleshoot says various things like Wifi doesn’t have a valid IP configuration, network cable is not properly plugged in or may be broken, Problem with wireless adapter or access point or default gateway not available. Sometimes it fixes IP issue, sometimes it doesn’t. Troubleshoot will always reset my network driver. I did 2 network resets manually too without success.
Yesterday I did a troubleshoot and I had that blue screen: System Thread Exception not handled, what failed: rtwlane6.sys which is my network adapter I am pretty sure. After I restarted it was deactivated. Whats that about?
I tried static IP, DNS, uninstalled driver numerous times, Power is set to best performance, did the prompt commands reset, release, renew flush, ran the HP hardware diagnostics which all passed.
I was researching more and found an old post in this community that made me think.
The Wifi icon in the lower bar and it doesn’t matter if its 2.4 or 5Ghz, sometimes it says Local area connection which then is Public, sometimes it says my normal network (netgear) which then is private. When 2.4Ghz is on local network, speed drops and it doesn’t take long to disconnect then. But 5G runs still fast and fine.
I also have sometimes that laptop icon instead of Wifi icon with 5Ghz and I am still connected. When I am disconnected I have that round ball thingy. Laptop is not wired.
As said as long as I am on 5Ghz all is fine despite the icon change and network status. I doubt its my router settings since all other devices are fine. I did try another modem today and had around 5 devices on each network and my laptop didnt work well on both networks.
My laptop is very fresh, haven’t installed many 3^rd^ party apps, only whats app, inSSIDer Wifi analyzer which both were installed because of the issue and Bitdefender Internet security. Issue was before I installed it. I do have Office 2007 but thats not a 3rd party I assume.
Any thoughts would be fantastic. Thanks for your time.
Silke
Cheers
Yes he did!
I wanted to but there were some covid restrictions that disallowed me from serving any beverages :(
Also, the session was a short one actually. Replace, test and done!
