PC needs to be repaired.
2021-06-20T07:36:38+00:00
Original title: wdfilter.sys missing or contains error.
Ok so after I got WdBoot.sys error, I did  chkdsk and sfc /scannow. It seems to go away, but another Wd error appears again, WdFilter.sys now. It seems that windows defender is having problem but I don't know how that happens. I'm also assuming the whole wd driver is faulty. Any solution?
Update: I just did a system restore and the wdboot.sys error came back.
Virginia M 41,985 Reputation points Independent Advisor
2021-06-20T10:26:19+00:00
Hello, I’m Virginia an independent advisor with 20 years of expertise in fixing my own & friends’ PC problems.
Which Windows 10 build are you running - 1909, 2004, 20H2 or 21H1?
The problem can be caused by malware:
Try running these programs:
MBAM free: https://www.malwarebytes.com/mwb-download/
Eset online scanner: http://www.eset.com/us/online-scanner/
Adwcleaner: https://www.malwarebytes.com/adwcleaner/
If these find one or more infections but do not fully remove them it will be wise to register with a malware removal site to receive dedicated malware removal instructions, an expert will remain with you throughout the process until confirmation that your PC is 100% clean.
Malwarebytes virus/malware removal forum:
https://forums.malwarebytes.com/forum/7-windows...
Bleeping computer malware/virus removal forum:
https://www.bleepingcomputer.com/forums/forum22...
Disclaimer - This post contains reference to non-Microsoft websites and there may be ads on the page for products & services including products frequently classified as a PUP (Potentially Unwanted Product). Please thoroughly research any product / service advertised on the page before you decide to use them. Your discretion is very much advised.
108 additional answers
    2021-06-22T06:13:05+00:00
    Ok so I did system restore, which not working. I am thinking of downloading a new wdboot.sys and put it in driver files.
    By the way, the bootable USB should be empty?
  2. Virginia M 41,985 Reputation points Independent Advisor
    2021-06-22T08:53:35+00:00
    It should be first in the list. It should say Undo my last restoration.
    2021-06-22T09:18:18+00:00
    Sorry, but there's only "Install"
  4. Virginia M 41,985 Reputation points Independent Advisor
    2021-06-22T09:35:25+00:00
    If restore failed then try in safe mode.
    The usb should contain either Windows installation media or Macrium Reflect boot files (if you created this) it should not contain any other files.
    There should be a troubleshoot option at the bottom of the screen.
