PC needs to be repaired.
2021-06-20T07:36:38+00:00
Original title: wdfilter.sys missing or contains error.
Ok so after I got WdBoot.sys error, I did  chkdsk and sfc /scannow. It seems to go away, but another Wd error appears again, WdFilter.sys now. It seems that windows defender is having problem but I don't know how that happens. I'm also assuming the whole wd driver is faulty. Any solution?
Update: I just did a system restore and the wdboot.sys error came back.
Virginia M 41,985 Reputation points Independent Advisor
2021-06-20T10:26:19+00:00
Hello, I’m Virginia an independent advisor with 20 years of expertise in fixing my own & friends’ PC problems.
Which Windows 10 build are you running - 1909, 2004, 20H2 or 21H1?
The problem can be caused by malware:
Try running these programs:
MBAM free: https://www.malwarebytes.com/mwb-download/
Eset online scanner: http://www.eset.com/us/online-scanner/
Adwcleaner: https://www.malwarebytes.com/adwcleaner/
If these find one or more infections but do not fully remove them it will be wise to register with a malware removal site to receive dedicated malware removal instructions, an expert will remain with you throughout the process until confirmation that your PC is 100% clean.
Malwarebytes virus/malware removal forum:
https://forums.malwarebytes.com/forum/7-windows...
Bleeping computer malware/virus removal forum:
https://www.bleepingcomputer.com/forums/forum22...
Disclaimer - This post contains reference to non-Microsoft websites and there may be ads on the page for products & services including products frequently classified as a PUP (Potentially Unwanted Product). Please thoroughly research any product / service advertised on the page before you decide to use them. Your discretion is very much advised.
108 additional answers
    2021-07-04T15:09:19+00:00
    YES!! I CAN BOOT!!
    Thank you thank you. I can't believe after 2 weeks of pain and agony I can finally start my old laptop.
    The first thing that greets me is: This copy of windows is not genuine.
    But I can ignore it anyway.
    May light guide your path,
    May sun warms you,
    May rain falls upon you,
    May god bless you,
    Until then I thank you 3000.
    I know this sounds exaggerated but I'm very happy rn. (if you have any social media i could give a visit haha)
    I bet this is your longest support work?
  2. Virginia M 41,985 Reputation points Independent Advisor
    2021-07-04T16:28:35+00:00
    Glad to hear the problem has been resolved & you’re very welcome to my help.
    Did the reset keep all your files? I hope you didn’t lose too much.
    I am on Facebook & Twitter.
    Yes it is but it is worth it for the positive outcome.
    2021-07-04T17:05:55+00:00
    In the end I did formatted my C: and reinstall. Backed up my personal files through that mini explorer from notepad.
    Was faster than I thought.
  4. Virginia M 41,985 Reputation points Independent Advisor
    2021-07-04T17:36:47+00:00
    Excellent.
    I would now recommend using disk imaging software in case of future problems.
    https://www.macrium.com/reflectfree
