PC needs to be repaired.
2021-06-20T07:36:38+00:00
Original title: wdfilter.sys missing or contains error.
Ok so after I got WdBoot.sys error, I did  chkdsk and sfc /scannow. It seems to go away, but another Wd error appears again, WdFilter.sys now. It seems that windows defender is having problem but I don't know how that happens. I'm also assuming the whole wd driver is faulty. Any solution?
Update: I just did a system restore and the wdboot.sys error came back.
Virginia M 41,985 Reputation points Independent Advisor
2021-06-20T10:26:19+00:00
Hello, I’m Virginia an independent advisor with 20 years of expertise in fixing my own & friends’ PC problems.
Which Windows 10 build are you running - 1909, 2004, 20H2 or 21H1?
The problem can be caused by malware:
Try running these programs:
MBAM free: https://www.malwarebytes.com/mwb-download/
Eset online scanner: http://www.eset.com/us/online-scanner/
Adwcleaner: https://www.malwarebytes.com/adwcleaner/
If these find one or more infections but do not fully remove them it will be wise to register with a malware removal site to receive dedicated malware removal instructions, an expert will remain with you throughout the process until confirmation that your PC is 100% clean.
Malwarebytes virus/malware removal forum:
https://forums.malwarebytes.com/forum/7-windows...
Bleeping computer malware/virus removal forum:
https://www.bleepingcomputer.com/forums/forum22...
Disclaimer - This post contains reference to non-Microsoft websites and there may be ads on the page for products & services including products frequently classified as a PUP (Potentially Unwanted Product). Please thoroughly research any product / service advertised on the page before you decide to use them. Your discretion is very much advised.
108 additional answers
    2021-06-20T12:37:10+00:00
    I did sfc scannow and DISM too but sfc comes with 100% verification along with "Windows resource protection could not start the repair service" and DISM comes out with source couldn't be found or something like that.
    I'm trying "chkdsk C: /f /r /x" because the error path is "windows\system32\drivers\wd\wdboot.sys/wdfilter.sys" I thought it might work.
  2. Virginia M 41,985 Reputation points Independent Advisor
    2021-06-20T12:42:00+00:00
    Then Windows is either too corrupted or has malware.
    You would require the installation media to be able to run DISM using the WIM source:
    https://www.tenforums.com/tutorials/7808-use-di...
    Part 6 or 7.
    I would post on one of the malware removal forums I mentioned just in case the problem is caused by malware.
    Note: This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as a PUP (Potentially Unwanted Products).
    Please do not download any repair tool which may be offered by this site other than the ones I mention/recommend.
    Thoroughly research any product which is mentioned here before you decide to download and install it.
    2021-06-20T13:05:56+00:00
    I'm pretty sure it's corrupted. Because, 2 days ago, I was updating a game called Roblox. 5 minutes into the game it goes BSOD with stop code "Thread stuck in device driver" then I tried fiddling the command prompt, more info on my other questions.
  4. Virginia M 41,985 Reputation points Independent Advisor
    2021-06-20T13:29:27+00:00
    As Windows is so corrupted I would recommend a clean install of Windows.
    If you could boot into Windows even with safe mode with networking then you could download Macrium Reflect & create their boot media to try & repair the boot &/or create a disk image to preserve your files.
    Otherwise I’m out of options.
