PC needs to be repaired.
2021-06-20T07:36:38+00:00
Original title: wdfilter.sys missing or contains error.
Ok so after I got WdBoot.sys error, I did  chkdsk and sfc /scannow. It seems to go away, but another Wd error appears again, WdFilter.sys now. It seems that windows defender is having problem but I don't know how that happens. I'm also assuming the whole wd driver is faulty. Any solution?
Update: I just did a system restore and the wdboot.sys error came back.
Virginia M 41,990 Reputation points Independent Advisor
2021-06-20T10:26:19+00:00
Hello, I’m Virginia an independent advisor with 20 years of expertise in fixing my own & friends’ PC problems.
Which Windows 10 build are you running - 1909, 2004, 20H2 or 21H1?
The problem can be caused by malware:
Try running these programs:
MBAM free: https://www.malwarebytes.com/mwb-download/
Eset online scanner: http://www.eset.com/us/online-scanner/
Adwcleaner: https://www.malwarebytes.com/adwcleaner/
If these find one or more infections but do not fully remove them it will be wise to register with a malware removal site to receive dedicated malware removal instructions, an expert will remain with you throughout the process until confirmation that your PC is 100% clean.
Malwarebytes virus/malware removal forum:
https://forums.malwarebytes.com/forum/7-windows...
Bleeping computer malware/virus removal forum:
https://www.bleepingcomputer.com/forums/forum22...
Disclaimer - This post contains reference to non-Microsoft websites and there may be ads on the page for products & services including products frequently classified as a PUP (Potentially Unwanted Product). Please thoroughly research any product / service advertised on the page before you decide to use them. Your discretion is very much advised.
108 additional answers
  1. Virginia M 41,990 Reputation points Independent Advisor
    2021-06-23T11:23:27+00:00
    Keep me updated.
    2021-06-23T11:24:22+00:00
    Sorry but I kind of not get it? Yes the error appears as "Your PC needs to be repaired" and there's 0xc000007b windows\system32\drivers\wd\wdboot.sys. This driver is missing or contains error.
    I did not get the file part you mentioned.
    2021-06-23T12:26:30+00:00
    Ok I did restore, problem same as before.
  4. Virginia M 41,990 Reputation points Independent Advisor
    2021-06-23T12:28:55+00:00
    Yes the restore would’ve undone the file replacement.
    Try with the files I posted on the MediaFire account. If those do not fix the problem then a clean install of Windows is needed.
