Can anyone help?
2021-07-02T15:06:33+00:00
Source
Udk User Service
Summary
Stopped working
Description
Faulting Application Path: C:\Windows\System32\svchost.exe
Problem signature
Problem Event Name: APPCRASH
Application Name: svchost.exe_UdkUserSvc
Application Version: 10.0.19041.546
Application Timestamp: 058e175a
Fault Module Name: combase.dll
Fault Module Version: 10.0.19041.1081
Fault Module Timestamp: 473ce9d1
Exception Code: c0000005
Exception Offset: 0000000000031434
OS Version: 10.0.19043.2.0.0.768.101
Locale ID: 18441
Additional Information 1: 40de
Additional Information 2: 40de6d0c7b148f18d8b1194dde94c489
Additional Information 3: fe9e
Additional Information 4: fe9e3d66834d8f3b959a02da202a4ad6
Extra information about the problem
Bucket ID: bba0a5ea7cd51a9c3016db1485aac959 (1159354835282872665)
    2021-07-03T16:21:01+00:00
    Thank you auggy.
    I did download the UiPath Studio software sometime in the middle or end of February as I was attending a brief introduction course on robotic process automation. I have not been launching the software after the one-day course.
    On 12th April, I installed 2 VMs using the Hyper-V Manager, with Windows Server 2019 OS installed. The Reliability Monitor showed poor stability since then, and I uninstalled the VMs.
    I re-installed the VMs about one week later, but had no time to use them until now. So I supposed they have nothing to do with the current issue.
    The Cisco Packet Tracer v8.0 (64-bit) was first installed probably on 28th may. Because of the crashes, I uninstalled and tried it out with v8.0 (32-bit). It didn't help.
    I later installed v7.3.1 instead, the problem persisted, even when I did not use it for a couple of days.
    Feel free to let me know if you need further information.
    Thank you.
    2021-07-03T17:29:47+00:00
    Since UiPath Studio software may have coincided with the appearance of the issue can you temporarily uninstall UiPath Studio software and see if it helps.
    2021-07-04T05:36:56+00:00
    Sure auggy, I have already uninstalled it.
    Will monitor for a few days before I come back to you again.
    Thanks.
    2021-07-04T12:17:39+00:00
    You're welcome, and good luck!
    2021-07-11T13:06:05+00:00
    Hi auggy,
    Unfortunately it happened again on 7th, 8th and today.
    Nothing was installed in this one week.
    Also did not use the Cisco Packet Tracer nor the VMs
    Regards
