Can anyone help?
2021-07-02T15:06:33+00:00
Source
Udk User Service
Summary
Stopped working
Description
Faulting Application Path: C:\Windows\System32\svchost.exe
Problem signature
Problem Event Name: APPCRASH
Application Name: svchost.exe_UdkUserSvc
Application Version: 10.0.19041.546
Application Timestamp: 058e175a
Fault Module Name: combase.dll
Fault Module Version: 10.0.19041.1081
Fault Module Timestamp: 473ce9d1
Exception Code: c0000005
Exception Offset: 0000000000031434
OS Version: 10.0.19043.2.0.0.768.101
Locale ID: 18441
Additional Information 1: 40de
Additional Information 2: 40de6d0c7b148f18d8b1194dde94c489
Additional Information 3: fe9e
Additional Information 4: fe9e3d66834d8f3b959a02da202a4ad6
Extra information about the problem
Bucket ID: bba0a5ea7cd51a9c3016db1485aac959 (1159354835282872665)
    2021-08-09T13:10:18+00:00
    No crashes for three days after the clean boot, but not been able to define which app seems to be causing the crash.
    I don't think it is wise to re-install the UiPath app since I am not likely to use it in near future.
    Should I monitor for a few more days before updating you again?
    What other likely causes do you think may contribute to the crashes all this while?
    2021-08-11T02:02:32+00:00
    Still no crashes? Yes, you could keep monitoring for a few more days.
    What apps and services were disabled for the clean boot?
    2021-08-22T03:51:33+00:00
    Updating you, auggy.
    The Cisco Packet Tracer app was removed for the clean boot. No crash for three days.
    On August 10, 2 crashes (svchost.exe_UdkUserSvc stopped working) happened.
    August 11-20, no crash.
    Auguat 21, re-install Cisco Packet Tracer. One crash each on 21st and 22nd (both were PacketTracer.exe stopped working).
    Unfortunately I seem not being able to provide any solid information for you to determine the cause.
