High "system" process disk usage
2021-07-20T15:06:03+00:00
I am having this issue from yesterday. My computer suddenly slow down. I went to task manager and saw system process at top of task manager window. I tried lot of stuff and did not work. I updated windows some days ago. I need help ASAP cause I use this computer for class.
    2021-07-26T16:42:50+00:00
    To uninstall the drivers follow the steps below.
    1. Audio driver
    Open Device Manager >> click sound, video and game controllers >> right- click your Audio driver >> click Uninstall Device.
    >> Download and install the Audio driver from the HP official support website.
    1. Display driver
    Open Device Manager >> click Display Adapters>> right- click your Display driver >> click Uninstall Device.
    >> Download and install the Display Driver.
    1. Bluetooth driver
    Open Device Manager >> click Bluetooth >> right- click your Bluetooth driver >> click Uninstall Device.
    >> Download and install the Bluetooth driver.
    1. WIFI driver
    >> Before uninstalling the WIFI driver, download the WIFI driver first.
    Open Device Manager >> click Network Adapters >> right- click your WIFI driver >> click Uninstall Device.
    >> Install the WIFI driver.
    Note: Monitor the Disk usage of the System every time you uninstall a driver. If the System usage is already fixed you don't have to uninstall other drivers.
    I hope this helps. Feel free to ask back any questions and keep me posted.
    2021-07-27T07:06:13+00:00
    Hey again,
    In hp's website, there is lot of drivers with the same name. I don't want to install the wrong driver andit amy cause more problems. What should I do ?
    2021-07-27T07:33:09+00:00
    You can go to the link below.
    https://support.hp.com/in-en/drivers/selfservic...
    You can try to use the "Detect my drivers" option.
    If you want to download and install it manually, select the most recent driver available.
    Standard Disclaimer: There are links to non-Microsoft websites.
    The pages appear to be providing accurate, safe information.
    2021-07-27T08:32:52+00:00
    I downloaded audio driver and uninstalled the old one and when I tried to install, windows crashed.
    2021-07-27T09:20:37+00:00
    Is it a BSOD error just like on the image below?
