High "system" process disk usage
2021-07-20T15:06:03+00:00
I am having this issue from yesterday. My computer suddenly slow down. I went to task manager and saw system process at top of task manager window. I tried lot of stuff and did not work. I updated windows some days ago. I need help ASAP cause I use this computer for class.
    2021-07-25T16:35:17+00:00
    Yes. It is not lagging as much.
    2021-07-25T16:45:35+00:00
    So there is a high possibility that it might be caused by a driver or other system services.
    I suggest that you start the PC normally then disable 3rd-party drivers(Display, Network, Bluetooth, Audio). Then check if the Disk usage is still the same.
    Refer to the link below on how to disable the drivers(Display, Network, Bluetooth, Audio).
    https://www.windowscentral.com/how-disable-devi...
    Let me know the result.
    Thanks.
    Standard Disclaimer: There are links to non-Microsoft websites.
    The pages appear to be providing accurate, safe information. Watch out for ads on the sites that may advertise products frequently classified as a PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the sites before you decide to download and install it.
    2021-07-26T05:57:56+00:00
    Before this problem happened, I installed Intel driver and support assistant. Do you think that could have cause any problem ? Their was a update about something like intel xe.... I forgot. I installed that driver. Later when I saw the issue, I uninstalled intel driver and support assistant and also uninstalled the driver, but the problem still exists. Btw before installing the app, yesterday their was same issue but seem to fix itself. I thought it was some windows update. My computer info is this if you a=wantedImage
    2021-07-26T13:03:36+00:00
    So the issue might be really caused by a driver.
    The last option I can recommend is uninstall and reinstalling all your 3rd-party drivers(Display, Network, Bluetooth, Audio)..
    Download and install the driver from HP official support website.
    2021-07-26T13:18:47+00:00
    How should I do that ?
