Indexing runs, completes, and then restarts and does it again.
2021-01-20T03:17:59+00:00
Windows 8.1, Lenovo Carbon X1 20A7.  The problem started for no reason I can think of.  No new programs installed, no material changes.  I ran System File Checker, CC Cleaner, Glary Utilities, and System Mechanic.  No luck.
2021-02-04T16:57:01+00:00
I found a fix.  Regedit, then search for Windows Search.  Click on SetupCompletedSuccessfully, and change the value to 1, save and close Registry.  Then Control Panel/Indexing Options/Advanced and click Rebuild.  This will take several hours, but you can use computer while it works.  When it says it's complete, reboot, go back to Regedit SetupCompletedSuccessfully, and change the value to 0.
5 additional answers
    2021-01-24T01:09:51+00:00
    I have deleted the windows.edb file, put Search in Manual mode and rebuilt it successfully.  Now when I reboot, Search does not restart the whole process, so that's a workaround until I need to search for a file created after the last rebuild.
    I'd like to find a permanent fix.  Do you think it would be worthwhile to run chkdsk?
    Any other ideas would be welcome.
    Thanks.
