PC freezes after being left idle for a few hours
2020-12-05T05:23:57+00:00
Hi all, my computer has been 'freezing' after bring left idle ever since i updated to Windows Version 20H2. Actually it might not even be the update but I'm not quite sure what is the issue here also :(
Here's what happened:
  • Left computer on overnight, with google chrome and telegram messenger minimized
  • In the morning, opened up chrome (at the YouTube page since last night), clicking on buttons on the website doesn't do anything. The start button still works, but clicking on any apps wont do anything. Also, I've realized that the telegram animated stickers previews are now all not moving anymore, and so did my animated wallpaper.
  • Used my phone to try to connect to my computer via Google remote desktop, says my computer is offline??
I'm using a custom build PC, bought it not too long ago on 11 June 2020, so I doubt there should be any hardware issues?
Did a full restore on 3 Nov 2020, but it still freezes after leaving it idle for a few hours.
Here are my PC specs:
r7 3700x
msi x570 tomahawk WIFI
gskill trident z neo 3600mhz 32gb kit
samsung 970evo plus 500gb nvme m.2
toshiba p300 2tb 7200rpm
msi rtx2060 super 8gb gaming x
seasonic focus+ gx 750w 80+ gold
Windows specs:
Edition Windows 10 Home
Version 20H2
Installed on ‎3/‎11/‎2020
OS build 19042.630
Experience Windows Feature Experience Pack 120.2212.31.0
2021-05-23T11:03:39+00:00
Had the exact same symptoms as OP ever since i upgraded from a Ryzen 7 1700 to a 3700x on a Asus Crosshair VI Hero. Tried pretty much everything the internet suggested although i dont even use Corsair Link or NZXT CAM, i've been using the old Aura Sync to control my RGB.
For the people still searching for a solution, try to disable Global C-state control in the BIOS:
I tried that as a last effort before returning the processor back but after1 week of use i have yet to experience a "freeze" with the C-state Control disabled.
I will report back in case i get another freeze but so far it seemed to solve my "freezing" problem.
42 additional answers
    2021-06-03T12:07:48+00:00
    This solved my problem! Went into BIOS and disabled C-State. Computer has not froze for 2 weeks since making the change. Good luck to all! Thank you so much, @McK-4268!
    2021-06-08T14:16:26+00:00
    Hi all
    Seems like the issue is resolved for me and the few people who read my post. Glad I could help. Almost a month without the aforementioned symptoms.
    I uploaded a video showing my unresponsive pc to further narrow down the problem and mitigate possible false diagnosis:
    https://www.youtube.com/watch?v=ewMTSqLTV48
    If you have symptoms like that then please try to disable "Global C-States" in your BIOS. (If another motherboard vendor is used then google where you can find the setting)
    Also, credits should go to Creativem0nster1 over on the Linus Tech Tips Forums because he first suggested the solution, yet it got too little attention:
    https://linustechtips.com/topic/1223050-new-pc-strange-windows-freezes-probable-cause-nzxt-cam/?do=findComment&comment=14627714
    HUGE thanks to this guy, im trying to spread the word.
    Note: The setting "Global C-States" is responsible for the reduced power consumption when your PC is in idle. But I'll take a working system over a bit more power draw at idle any day of the week ;)
    Regards
    McK
    2021-06-08T14:41:16+00:00
    I've been having the exact same issue as described in this thread. I hope the CAM software gets an update to address this soon. I just turned off my CAM software today after having this issue since updating to the 20H2 update back in September. I had no issues prior to 20H2. I too also thought it was a GPU issue due to having 3 monitors hooked up to my graphics card, but I don't have any way of testing that. It wasn't until today that I noticed that it seemed to be crashing primarily when engaging with the PC after it had been idling for a little bit (even when it's playing YouTube video's). Stumbled on this thread when searching that specific symptom.
    old
    Ryzen 5 - 2600
    Gigabyte B450 Pro wifi
    GTX 1660ti - 6GB
    16GB RAM
    NZXT H500i case with CAM hub and CAM software.
    I just upgraded my CPU and MOBO last week hoping that would solve my issue. That did not solve my issue (also did a fresh install then as well). I also tried changing out the RAM in December and that didn't help either.  I also tried 2 clean installs over the course of a couple months and rolling back display drivers and not using GeForce game ready drivers -  made the mistake of doing a fresh install before trying to roll back the update when I did it in September so I couldn't roll back to the previous version of Windows - but none of that helped. .
    current
    Ryzen 7 5800x
    Asus B550 Gaming F
    GTX 1660ti - 6GB
    64GB RAM
    I'm very grateful for all the work that everyone has put into this thread! Seriously hoping that this issue will no longer haunt my dreams.
    UPDATE:
    3 months have passed and I have not had a single crash.
    All I had to do was disable the NZXT CAM software that I was using to control my RGB hub.
    2021-06-14T14:22:40+00:00
    Any luck after disabling NZXT CAM? That's what solved the issue for me, haven't had crashes since I did that 3 months ago.
