PC freezes after being left idle for a few hours
2020-12-05T05:23:57+00:00
Hi all, my computer has been 'freezing' after bring left idle ever since i updated to Windows Version 20H2. Actually it might not even be the update but I'm not quite sure what is the issue here also :(
Here's what happened:
  • Left computer on overnight, with google chrome and telegram messenger minimized
  • In the morning, opened up chrome (at the YouTube page since last night), clicking on buttons on the website doesn't do anything. The start button still works, but clicking on any apps wont do anything. Also, I've realized that the telegram animated stickers previews are now all not moving anymore, and so did my animated wallpaper.
  • Used my phone to try to connect to my computer via Google remote desktop, says my computer is offline??
I'm using a custom build PC, bought it not too long ago on 11 June 2020, so I doubt there should be any hardware issues?
Did a full restore on 3 Nov 2020, but it still freezes after leaving it idle for a few hours.
Here are my PC specs:
r7 3700x
msi x570 tomahawk WIFI
gskill trident z neo 3600mhz 32gb kit
samsung 970evo plus 500gb nvme m.2
toshiba p300 2tb 7200rpm
msi rtx2060 super 8gb gaming x
seasonic focus+ gx 750w 80+ gold
Windows specs:
Edition Windows 10 Home
Version 20H2
Installed on ‎3/‎11/‎2020
OS build 19042.630
Experience Windows Feature Experience Pack 120.2212.31.0
2021-05-23T11:03:39+00:00
Had the exact same symptoms as OP ever since i upgraded from a Ryzen 7 1700 to a 3700x on a Asus Crosshair VI Hero. Tried pretty much everything the internet suggested although i dont even use Corsair Link or NZXT CAM, i've been using the old Aura Sync to control my RGB.
For the people still searching for a solution, try to disable Global C-state control in the BIOS:
I tried that as a last effort before returning the processor back but after1 week of use i have yet to experience a "freeze" with the C-state Control disabled.
I will report back in case i get another freeze but so far it seemed to solve my "freezing" problem.
42 additional answers
    2021-03-24T16:16:32+00:00
    I've been having the issue since early December, however I kind of fixed it in January by re-seating my RAM, running RAM diagnostics, system re-storing, then re-downloading my Drivers. Like you guys, I have a newer build and I "was" having the exact same problems. BUT last night it started up again after almost 2 full months of not "freezing". Any solutions yet for yall?
    2021-04-09T06:00:01+00:00
    Thank you for articulating your issues so well.  It's exactly what I'm experiencing.  I upgraded a week or so ago and installed a fresh copy of W10 and I keep getting this crash.  It's a fresh install, so I thought it was something to do with the hardware.  I thought it might be a power issue, but I'm glad to see it might just be software related.  In my case, I have the Corsair Link and I just uninstalled it and will see how that goes.  The old build with 20h2 was running just fine.
    Old:
    Ryzen 3600
    Gigabyte b350m Gaming
    Crucial Ballistix 3600Mhz
    RTX 2080 Hybrid
    Samsung 960 Evo 1TB
    Seasonic 750w Titanium
    Windows Pro 20h2
    New:
    Ryzen 5800x
    MSI MPG b550 Gaming Plus
    The rest is the same.
    I'm running the GPU pump to a motherboard header and I reduced the voltage in the bios in order to get ride of pump whine - it's pretty bad.  I thought my issue was related to the volts getting too low or something.  I'm going to cross my fingers about the Corsair Link and say a prayer.
    2021-05-12T04:20:16+00:00
    It seems to be a Ryzen / AMD and Windows 10 issue. Is now affecting a lot of people.
    2021-05-12T04:50:02+00:00
    It's May 2021 I've the same problem - same processor and mobo chipset - would appear this issue is now becoming more widespread so some incompatibility must have been released in updates. Seems to me very related to Ryzen processors.
