PC freezes after being left idle for a few hours
2020-12-05T05:23:57+00:00
Hi all, my computer has been 'freezing' after bring left idle ever since i updated to Windows Version 20H2. Actually it might not even be the update but I'm not quite sure what is the issue here also :(
Here's what happened:
  • Left computer on overnight, with google chrome and telegram messenger minimized
  • In the morning, opened up chrome (at the YouTube page since last night), clicking on buttons on the website doesn't do anything. The start button still works, but clicking on any apps wont do anything. Also, I've realized that the telegram animated stickers previews are now all not moving anymore, and so did my animated wallpaper.
  • Used my phone to try to connect to my computer via Google remote desktop, says my computer is offline??
I'm using a custom build PC, bought it not too long ago on 11 June 2020, so I doubt there should be any hardware issues?
Did a full restore on 3 Nov 2020, but it still freezes after leaving it idle for a few hours.
Here are my PC specs:
r7 3700x
msi x570 tomahawk WIFI
gskill trident z neo 3600mhz 32gb kit
samsung 970evo plus 500gb nvme m.2
toshiba p300 2tb 7200rpm
msi rtx2060 super 8gb gaming x
seasonic focus+ gx 750w 80+ gold
Windows specs:
Edition Windows 10 Home
Version 20H2
Installed on ‎3/‎11/‎2020
OS build 19042.630
Experience Windows Feature Experience Pack 120.2212.31.0
2021-05-23T11:03:39+00:00
Had the exact same symptoms as OP ever since i upgraded from a Ryzen 7 1700 to a 3700x on a Asus Crosshair VI Hero. Tried pretty much everything the internet suggested although i dont even use Corsair Link or NZXT CAM, i've been using the old Aura Sync to control my RGB.
For the people still searching for a solution, try to disable Global C-state control in the BIOS:
I tried that as a last effort before returning the processor back but after1 week of use i have yet to experience a "freeze" with the C-state Control disabled.
I will report back in case i get another freeze but so far it seemed to solve my "freezing" problem.
42 additional answers
  1. Deleted
    2021-01-10T17:01:56+00:00
    After uninstalling Corsair Link 4 on 8th January. My Computer was on yesterday for 13 hours with no freezing at all and has been on for 5 hours today with no freezes either.
    Will update if anymore occur
    2021-02-10T17:42:38+00:00
    Hi, did you manage to find a solution, the same thing happens to me.
    I kept my task manager open and noticed that when this happens, the readouts mess up, they show -1% usage on the GPU and 0% on all hard drives, my commander pro stops interfacing with the iCUE software, I lose internet access and any video I was playing stops, Wallpaper engine also stops working.
    I wanted to know if you found a solution.
    Im not sure if this matters but my GPU is connected via a Gen 3 Riser cable, although from the looks of this thread it seems most likely windows is the issue so im not sure if its hardware or software related so I wanted to know if you've made any progress.
    2021-02-26T02:45:05+00:00
    I’m indeed having the same problem! I thought maybe it was Wallpaper Engine but after a while Ive realized it’s not. Only when I’m idle after a certain period of time that it decides to freeze. Just like you I can do some things but I have to force restart my computer. It looks like no one really knows how to fix it?
