PC freezes after being left idle for a few hours
2020-12-05T05:23:57+00:00
Hi all, my computer has been 'freezing' after bring left idle ever since i updated to Windows Version 20H2. Actually it might not even be the update but I'm not quite sure what is the issue here also :(
Here's what happened:
  • Left computer on overnight, with google chrome and telegram messenger minimized
  • In the morning, opened up chrome (at the YouTube page since last night), clicking on buttons on the website doesn't do anything. The start button still works, but clicking on any apps wont do anything. Also, I've realized that the telegram animated stickers previews are now all not moving anymore, and so did my animated wallpaper.
  • Used my phone to try to connect to my computer via Google remote desktop, says my computer is offline??
I'm using a custom build PC, bought it not too long ago on 11 June 2020, so I doubt there should be any hardware issues?
Did a full restore on 3 Nov 2020, but it still freezes after leaving it idle for a few hours.
Here are my PC specs:
r7 3700x
msi x570 tomahawk WIFI
gskill trident z neo 3600mhz 32gb kit
samsung 970evo plus 500gb nvme m.2
toshiba p300 2tb 7200rpm
msi rtx2060 super 8gb gaming x
seasonic focus+ gx 750w 80+ gold
Windows specs:
Edition Windows 10 Home
Version 20H2
Installed on ‎3/‎11/‎2020
OS build 19042.630
Experience Windows Feature Experience Pack 120.2212.31.0
2021-05-23T11:03:39+00:00
Had the exact same symptoms as OP ever since i upgraded from a Ryzen 7 1700 to a 3700x on a Asus Crosshair VI Hero. Tried pretty much everything the internet suggested although i dont even use Corsair Link or NZXT CAM, i've been using the old Aura Sync to control my RGB.
For the people still searching for a solution, try to disable Global C-state control in the BIOS:
I tried that as a last effort before returning the processor back but after1 week of use i have yet to experience a "freeze" with the C-state Control disabled.
I will report back in case i get another freeze but so far it seemed to solve my "freezing" problem.
42 additional answers
  1. Deleted
  2. Lester Bernard Reyes 85,510 Reputation points Independent Advisor
    2020-12-05T05:39:10+00:00
    Hi and thanks for reaching out. My name is Bernard an Independent Advisor and a Windows fan like you. I'll be happy to help you out today.
    I actually have the same problem as before and by following the steps provided below fixed my issue, I hope this works for you as well.
    Method 1. Do clean boot:
    A “clean boot” starts Windows with a minimal set of drivers and startup programs, so that you can determine whether a background program is interfering with your game or program.
    • In the search box on the taskbar, type msconfig and select System Configuration from the results.
    • On the Services tab of System Configuration, select Hide all Microsoft services, and then select Disable all.
    • On the Startup tab of System Configuration, select Open Task Manager.
    • Under Startup in Task Manager, for each startup item, select the item and then select Disable.
    • Close Task Manager.
    • On the Startup tab of System Configuration, select OK. When you restart the computer, it's in a clean boot environment.
    troubleshooting reference: https://support.microsoft.com/en-us/help/929135...
    Method 2. Run memory diagnostic tool: Memory diagnostic tool is a RAM test to check if there is any issues with RAM.
    • Press Windows key + R then type in mdsched.exe hit OK then restart the device.
    Method 3. Set the PC to best performance:
    Press windows key + Pause/Break (or go to file explorer and right click This PC and click properties)
    click on Advanced system settings> Under Performance click settings> Click Adjust for best performance and click OK
    Note: this will reduce all appearance settings you have but will optimize the performance of the PC.
    Let me know how does it goes and I hope that helps.
    Bernard
    Independent Advisor
