DTS Sound Unbound Makes Audio Distorted
2020-10-06T21:14:57+00:00
When I enable DTS Sound Unbound (DTS Headphone X) the audio becomes distorted and the only fix is to disable the surround sound. I am using a Logitech G Pro X Headset.
    2021-05-15T12:07:02+00:00
    Definetly does not work. It always goes back automatically to deactivated. I tried a different headset and it works. I tried a 2.1 sound system and it works. As soon as you connect the Pro X headset it deactivates it self even when the spatial surround sound is turned on. Even if spatial surround was turned on prior to connecting the Pro X headset... immediatly after connecting it goes back to deactivated. Now the issue is not sound unbound anymore but it is logitech who needs to fix this!
    2021-05-16T12:45:37+00:00
    Its working for me now as he showed me how to enable it.
    From Windows sound tray icon (right bottom corner) wont work, I enabled it inside Setting app ->  System -> Sound -> Device properties
    you can change spatial sound there.
    2021-05-27T23:31:31+00:00
    So, thank you for the update? I don't know if this new update/"fix" still feels like it requires a lot of work... My stuff can mess up still if I minimize the app, mute some sound or something. I will take it for now, but hope you get us a better fix soon. DTS app sucks so far. rip... Logitech still makes the best hardware in my opinion, but once again they need to step up their game.
    Thanks, Mike
