Following the advice of another user I have installed Intel's bluetooth drivers v21.110.0.3 and, at last, it works. It was the only option left to apply and the one that I was reluctant to use. I was hoping that the incompatibility problem of the latest Intel drivers with the controller's bluetooth would be solved. But a month later I have given up. It already works with the COD games and hopefully with Cyberpunk.
Hi DS,
Awesome you nailed it, it is a bluetooth driver issue then.
I'm glad it's working for you, playing with the controller is going to fun.
I guess the xbox wireless controller works with intel bluetooth driver 21.110.0.3.
I also posted my bluetooth driver 21.110.0.3 on the November 20 to you, maybe you just missed it :)
Here is my comment on Nov 2020:
My machine has "Intel(R) Wireless Bluetooth (R) " driver 21.110.0.3 installed and works.
However, there is a glitch with mine, a lot of times when launching some games at the start, bluetooth will not respond.
So i go into Bluetooth setting remove the Xbox wireless Controller 987********" then on the controller hold down the Bluetooth button for 5 secs then add an discover the Bluetooth controller in Bluetooth again. I go back into the game and it works.
- Go to "Control Panel".
- "Add devices and printers".
- Press the sync button on the rear for 5 seconds on the Xbox controller.
- Click on “Add a device”.
- Follow the on screen instructions.
Troubleshooting:
If it fails, go back to your devices and make sure that it isnt already connected. If it is, right-click and remove device. Then proceed to step 3.
check MS update KB 4580364 is installed on your system.
https://support.microsoft.com/en-gb/help/4580364/windows-10-update-kb4580364
In theory it should work on the latest driver.
A stab in the dark perhaps, you could try installing "Intel(R) Wireless Bluetooth (R) " driver 21.110.0.3 if none of the above works.
Guys, because i'm am giving free support and advice, please subscribe to help support my youtube channel, keeps me involved and to help everyone. I need 1000 subscribers and 4000 watch time to get some cash :( which seems impossible atm.
DumDumTech channel is
