advanced power options and csenabled
2020-11-03T11:21:15+00:00
Hi
Advanced power options went missing after the last update. No processor options, usb, gpu power, etc. The usual fix of CSEnabled in regedit is no longer there. The fan speed is out of control even with the slider bar set to better battery. Any help would be appreciated.  thanks
2021-08-25T15:45:27+00:00
Hi All,
I too was fed up with this issue getting nowhere online.
I created a short script that will change req items to allow for advanced options to be displayed.
$sting77 = "HKLM\SYSTEM\CurrentControlSet\Control\Power\PowerSettings"<br><br>$querylist =  reg query $sting77<br><br>foreach ($regfolder in $querylist){<br><br>    <br><br>    $active = $regfolder -replace "HKEY_LOCAL_MACHINE" , "HKLM:"<br><br>    <br><br>    Get-ItemProperty -Path $active<br><br>    Set-ItemProperty -Path "$active" -Name "Attributes" -Value '2'<br><br>    <br><br>    }
Run this in an Elevated Powershell ISE and it should fix it straight away as mine are now showing:
56 additional answers
    2021-04-23T16:12:05+00:00
    This does not work.  They have been totally removed except for  "Balanced".  So how can this "Show" something that no longer exists?
    2021-04-23T16:17:05+00:00
    correct. but, the reg files sometimes get wiped out when MS has a major update.
    2021-04-23T16:21:49+00:00
    I don't like the pre-made power plans and manually set all of my own. So I suggest you try to load the .REG options you want, create a custom plan, and then go through and pick all of the options you want. I primarily want to control the CPU and the cooling state and these are now available and working like a charm. Try it that way and let me know how it goes. All the other settings are pretty straight forward.
    2021-04-23T16:23:28+00:00
    Well, I can only live in the present! Haha. I have NO idea why MS is messing with us like this. Such a joke. I agree. It may just be a temporary solution, but I will push off any updates as long as I can.
