H&R BLOCK 2019 BUSINESS SOFTWARE WILL NOT OPEN ANY MORE
2020-10-07T00:03:20+00:00
This is Windows 10.
I had been using the 2019 H&R Block business software just fine. Last time used was July 15, 2020.
Went to open to prepare Sub-S return on Sept 12 and kept getting an error message saying it could not open. I tried having Geek Squad look at it. They spent about 2 1/2 hours running diagnostics and could not figure it out. I had another IT pro look at it for about 3 hours, ran diagnostics and the best he could figure was that it was a Microsoft update that somehow corrupted the ordering sequence for the program to open. All of my clients are locked up now. The other thing is that it also corrupted the 2018 program so I cannot access those files either.
Tried downloading a new 2019 Block program. Overwrote the old one. Still same problem. Loaded the software from the disc. Same problem.
Trying to get through to Block is a joke. You will spend hours on the phone.
Any thoughts?
    2021-03-13T13:26:15+00:00
    Same issue as NV Steve
    2021-03-14T22:02:37+00:00
    Thanks.  This worked for me.  I cannot see the other returns, but it worked to get the software usable.
    2021-03-14T22:11:46+00:00
    Yes THIS is a Microsoft problem, same exact thing just happened to my 2020 HRblock Business after teh last update.  Microsoft's updates screwed the HRblock program up.
    2021-03-14T22:14:54+00:00
    What about hrblock 2020 business.  Mine was working until the latest update from Microsoft.  Need to file the business extension and cannot since it keeps crashing.
    Session Summary Information:
    Date/Time: 3/14/2021 5:56:32 PM
    ApplicationVersion: 20.0.7569.25573
    CommandLine: "C:\Program Files (x86)\H&R Block Business\H&R Block Business 2020\HRB.Business.exe"
    CurrentCultureName: en-US
    CurrentUICultureName: en-US
    DnsDomainName:
    Duration: 00:00:25.6373263
    HostName: LAPTOP-PIASSBOK
    MemoryMB: 16252
    OSArchitecture: Amd64
    OSCultureName: en-US
    OSFullNameWithServicePack: Windows 10
    OSVersion: 10.0.19041
    ProcessorCores: 12
    RuntimeVersion: 4.0.30319.42000
    TerminalServer: False
    Prism.Modularity.ModuleInitializeException: An exception occurred while initializing module 'TransitionProcessorResolverModule'.
        - The exception message was: Resolution of the dependency failed, type = 'HRB.Business.Interview.Transitions.TransitionProcessorResolverModule', name = '(none)'.
    Exception occurred while: while resolving.
    Exception is: CompositionException - The composition produced a single composition error. The root cause is provided below. Review the CompositionException.Errors property for more detailed information.
    1) This instance cannot be used because it encountered a fatal error
    Resulting in: Could not open transactional storage: C:\ProgramData\H&R Block Business\H&R Block Business 2020\DataStore\Data
    Resulting in: An exception occurred while trying to create an instance of type 'Sfs.Max.Infrastructure.MaxFormsetServerHost'.
    Resulting in: Cannot activate part 'Sfs.Max.Infrastructure.MaxFormsetServerHost'.
    Element: Sfs.Max.Infrastructure.MaxFormsetServerHost -->  Sfs.Max.Infrastructure.MaxFormsetServerHost -->  AssemblyCatalog (Assembly="Sfs.Max.Infrastructure, Version=20.0.7569.25552, Culture=neutral, PublicKeyToken=null")
    Resulting in: Cannot get export 'Sfs.Max.Infrastructure.MaxFormsetServerHost (ContractName="Sfs.Runtime.Structure.Forms.Client.IFormsetEnvironment")' from part 'Sfs.Max.Infrastructure.MaxFormsetServerHost'.
    Element: Sfs.Max.Infrastructure.MaxFormsetServerHost (ContractName="Sfs.Runtime.Structure.Forms.Client.IFormsetEnvironment") -->  Sfs.Max.Infrastructure.MaxFormsetServerHost -->  AssemblyCatalog (Assembly="Sfs.Max.Infrastructure, Version=20.0.7569.25552, Culture=neutral, PublicKeyToken=null")
    Resulting in: Cannot set import 'HRB.Business.Interview.Transitions.ImportTransitionProcessor..ctor (Parameter="formsetEnvironment", ContractName="Sfs.Runtime.Structure.Forms.Client.IFormsetEnvironment")' on part 'HRB.Business.Interview.Transitions.ImportTransitionProcessor'.
    Element: HRB.Business.Interview.Transitions.ImportTransitionProcessor..ctor (Parameter="formsetEnvironment", ContractName="Sfs.Runtime.Structure.Forms.Client.IFormsetEnvironment") -->  HRB.Business.Interview.Transitions.ImportTransitionProcessor -->  AssemblyCatalog (Assembly="HRB.Business, Version=20.0.7569.25573, Culture=neutral, PublicKeyToken=null")
    Resulting in: Cannot get export 'HRB.Business.Interview.Transitions.ImportTransitionProcessor (ContractName="HRB.Business.Interview.Transitions.ITopicTransitionProcessor")' from part 'HRB.Business.Interview.Transitions.ImportTransitionProcessor'.
    Element: HRB.Business.Interview.Transitions.ImportTransitionProcessor (ContractName="HRB.Business.Interview.Transitions.ITopicTransitionProcessor") -->  HRB.Business.Interview.Transitions.ImportTransitionProcessor -->  AssemblyCatalog (Assembly="HRB.Business, Version=20.0.7569.25573, Culture=neutral, PublicKeyToken=null")
    At the time of the exception, the container was:
      Resolving HRB.Business.Interview.Transitions.TransitionProcessorResolverModule,(none)
      Resolving parameter 'processors' of constructor HRB.Business.Interview.Transitions.TransitionProcessorResolverModule(Prism.Events.IEventAggregator eventAggregator, System.Collections.Generic.IEnumerable`1[[HRB.Business.Interview.Transitions.ITopicTransitionProcessor, HRB.Business, Version=20.0.7569.25573, Culture=neutral, PublicKeyToken=null]] processors)
        Resolving System.Collections.Generic.IEnumerable`1[HRB.Business.Interview.Transitions.ITopicTransitionProcessor],(none)
        Check the InnerException property of the exception for more information. If the exception occurred
        while creating an object in a DI container, you can exception.GetRootException() to help locate the
        root cause of the problem. ---> Unity.Exceptions.ResolutionFailedException: Resolution of the dependency failed, type = 'HRB.Business.Interview.Transitions.TransitionProcessorResolverModule', name = '(none)'.
     ---> System.ComponentModel.Composition.CompositionException: The composition produced a single composition error. The root cause is provided below. Review the CompositionException.Errors property for more detailed information.
       at System.ComponentModel.Composition.Hosting.CompositionServices.GetExportedValueFromComposedPart(ImportEngine engine, ComposablePart part, ExportDefinition definition)
       at System.ComponentModel.Composition.Hosting.CatalogExportProvider.GetExportedValue(CatalogPart part, ExportDefinition export, Boolean isSharedPart)
       at System.ComponentModel.Composition.Hosting.CatalogExportProvider.CatalogExport.GetExportedValueCore()
       at System.ComponentModel.Composition.Primitives.Export.get_Value()
       at System.ComponentModel.Composition.ExportServices.GetCastedExportedValueT
       at System.ComponentModel.Composition.ExportServices.<>c__DisplayClass13_0`2.<CreateSemiStronglyTypedLazy>b__1()
       at System.Lazy`1.CreateValue()
       at System.Lazy`1.LazyInitValue()
       at System.Lazy`1.get_Value()
       at Sfs.Max.Infrastructure.MefUnityIntegration.EnumerableResolutionStrategy.<>c__91.&lt;ResolveEnumerable&gt;b__9_0(Lazy1 part)
       at System.Linq.Enumerable.WhereSelectListIterator`2.MoveNext()
       at System.Collections.Generic.List1.InsertRange(Int32 index, IEnumerable1 collection)
       at Sfs.Max.Infrastructure.MefUnityIntegration.EnumerableResolutionStrategy.ResolveEnumerableT
       at Sfs.Max.Infrastructure.MefUnityIntegration.EnumerableResolutionStrategy.PreBuildUp(IBuilderContext context)
       at Unity.Builder.BuilderContext.NewBuildUp(Type type, String name, Action`1 childCustomizationBlock)
       at Unity.ResolverPolicy.NamedTypeDependencyResolverPolicy.Resolve(IBuilderContext context)
       at lambda_method(Closure , IBuilderContext )
       at Unity.ObjectBuilder.BuildPlan.DynamicMethod.DynamicBuildPlanGenerationContext.<>c__DisplayClass16_0.<GetBuildMethod>b__0(IBuilderContext context)
       at Unity.ObjectBuilder.BuildPlan.DynamicMethod.DynamicMethodBuildPlan.BuildUp(IBuilderContext context)
       at Unity.Strategies.BuildPlanStrategy.PreBuildUp(IBuilderContext context)
       at Unity.UnityContainer.ThrowingBuildUp(IBuilderContext context)
       --- End of inner exception stack trace ---
       at Unity.UnityContainer.Resolve(Type typeToBuild, String nameToBuild, ResolverOverride[] resolverOverrides)
       at Unity.UnityContainerExtensions.Resolve(IUnityContainer container, Type t, ResolverOverride[] overrides)
       at Prism.Unity.Ioc.UnityContainerExtension.Resolve(Type type)
       at Prism.Modularity.ModuleInitializer.CreateModule(String typeName)
       at Prism.Modularity.ModuleInitializer.CreateModule(IModuleInfo moduleInfo)
       at Prism.Modularity.ModuleInitializer.Initialize(IModuleInfo moduleInfo)
       at Prism.Modularity.ModuleInitializer.HandleModuleInitializationError(IModuleInfo moduleInfo, String assemblyName, Exception exception)
       at Prism.Modularity.ModuleManager.LoadModulesThatAreReadyForLoad()
       at Prism.Modularity.ModuleManager.LoadModuleTypes(IEnumerable`1 moduleInfos)
       at Prism.Modularity.ModuleManager.LoadModulesWhenAvailable()
       at Prism.Modularity.ModuleManager.Run()
       at Prism.Unity.UnityBootstrapper.InitializeModules()
       at HRB.Business.BootStrapper.InitializeModules()
       at Prism.Unity.UnityBootstrapper.Run(Boolean runWithDefaultConfiguration)
       at HRB.Business.App.OnStartup(StartupEventArgs e)
       at System.Windows.Application.<.ctor>b__1_0(Object unused)
       at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
       at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
    2021-03-14T23:44:05+00:00
    It seems like its both Microsoft's (MS) and H&R Block's problem.  Block's Premium's software was not impacted on my computer by the MS updates, just their Business software.  So, I think the way Block wrote the Business software is part of the problem.
