Bluetooth audio stuttering and lagging
2020-11-27T23:17:25+00:00
This issue has persisted for 5 months now. I am unable to use bluetooth headphones with my Dell XPS 15 9550 because audio and video is constantly interrupted with static. I am able to properly connect and pair my device to the laptop but for example youtube videos lag down and stutter almost like .5x speed. There is a constant interference and so the audio ends up choppy in songs or videos. I have done all troubleshooting with the headphones and audio and bluetooth settings. My Bose QC 35s also are able to connect and function with any other device except my laptop. I suspect it had something to do with a windows update I did over the summer but i am not sure
2020-12-03T19:13:14+00:00
I have the same issue on a Dell Inspiron 7460. It started after the last Windows 10 update in November, Windows 10 version 20H2.  And my headphones are Sony WH-1000XM4.
The headphones always worked very well, now it stuttering and don't stop, becoming terrible to listen to anything.
The suggestions made here did not work.
I found a solution on the web, if you would like to try, but this fix disable the option to use the headphones as headset:
"Press the Windows key and start typing "control panel" to find the icon to open the Control Panel. (As of the time of writing, Windows 10 does not have a way to change this setting via the new 'Settings' interface.)
  1. Find 'Devices and Printers' and double-click it.
  2. Find your paired headphones. The icon may not look like your headphones, but hopefully you should be able to find it.
  3. Right-click the icon and select 'Properties'.
  4. Select the 'Services' tab at the top.
  5. Under 'Bluetooth Services', if 'Hands-free Telephony' is checked, uncheck it.
  6. Click OK.
The audio may cut out as it saves the new settings (you may need to adjust your volumes in the Volume Mixer)"
For me is working fine after I made this change. Hope you find a solution.
67 additional answers
    2021-03-04T11:42:28+00:00
    This works for me too, but appears to activate the microphone as well. Also, the sound quality is horrible - but at least it's not stuttering...
    I have now solved all my problems. I ordered a Bluetooth 5.0 adapter for £7.99 from Amazon.co.uk, and it works perfectly!
    (RMFC USB Bluetooth 5.0 Dongle Adapter, Mini Bluetooth Dongle Audio Transmitter Receiver Supports Win 7/8/8.1/10, Wireless Bluetooth USB Adapter for PC/Headset/Speakers/TV/Car/Keyboard/Printers)
    It comes with a specific driver on mini-cd (Don't worry, it will fit inside your regular CD-ROM)
    IMPORTANT Please Note: You will need a spare USB 3.0 or higher.
    2021-03-14T15:24:08+00:00
    This did it for me, thank you!!
    2021-03-17T22:11:13+00:00
    I have (finally) managed to resolve this problem. I thought I'd share the solution here. I don't have enough Windows know-how to understand why it works. So keep in mind:
    • I cannot say with any degree of certainty that this solution will work for everyone (or even anyone).
    • Try this at your own risk. I have no idea whether this might introduce new issues to your system.
    In Device Manager go to View > Show hidden devices. A new category appears ("Bluetooth Virtual Devices"). Expand the category and uninstall all devices found therein (Right click > Uninstall device). Reboot. Enable/activate Bluetooth and connect your audio device.
    That's what did it for me. Hope this helps some of you too!
    yep! That way fixed my issue with Asus BT400 and Sony WH-XB900N!
    2021-03-25T22:10:15+00:00
    DELL XPS 15 9550 with wireless 1830 BT 4.1 LE adapter, and I got the same problem after updating to W10 Pro 20H2, just weeks ago.
    I tried everything, and of course I deinstalled all BT devices and adpaters, visible and hidden, deleted BT software and drivers, cleaned the registry, and installed again.
    And all that I got after the W10 20H2 update from my BT audio devices (two handsfree sets and one JBL speaker), is some crappy delayed noise that keeps stuttering all the time.
    I have had to switch to my smartphone for video meetings while I wait for some wired handsfree kit to arrive. This is more than annoying!  :-(
