Bluetooth audio stuttering and lagging
2020-11-27T23:17:25+00:00
This issue has persisted for 5 months now. I am unable to use bluetooth headphones with my Dell XPS 15 9550 because audio and video is constantly interrupted with static. I am able to properly connect and pair my device to the laptop but for example youtube videos lag down and stutter almost like .5x speed. There is a constant interference and so the audio ends up choppy in songs or videos. I have done all troubleshooting with the headphones and audio and bluetooth settings. My Bose QC 35s also are able to connect and function with any other device except my laptop. I suspect it had something to do with a windows update I did over the summer but i am not sure
2020-12-03T19:13:14+00:00
I have the same issue on a Dell Inspiron 7460. It started after the last Windows 10 update in November, Windows 10 version 20H2.  And my headphones are Sony WH-1000XM4.
The headphones always worked very well, now it stuttering and don't stop, becoming terrible to listen to anything.
The suggestions made here did not work.
I found a solution on the web, if you would like to try, but this fix disable the option to use the headphones as headset:
"Press the Windows key and start typing "control panel" to find the icon to open the Control Panel. (As of the time of writing, Windows 10 does not have a way to change this setting via the new 'Settings' interface.)
  1. Find 'Devices and Printers' and double-click it.
  2. Find your paired headphones. The icon may not look like your headphones, but hopefully you should be able to find it.
  3. Right-click the icon and select 'Properties'.
  4. Select the 'Services' tab at the top.
  5. Under 'Bluetooth Services', if 'Hands-free Telephony' is checked, uncheck it.
  6. Click OK.
The audio may cut out as it saves the new settings (you may need to adjust your volumes in the Volume Mixer)"
For me is working fine after I made this change. Hope you find a solution.
67 additional answers
    2022-01-04T16:31:49+00:00
    This fixed the audio skipping for me, but now my earbuds don't work in Teams calls for audio or microphone. Might be great if you're just using it for listening to music or whatever, though.
    2022-01-05T14:51:18+00:00
    Yes, If you connect more than 1 device wirelessly (not including dongle ones) then there is lag in bluetooth mouse and stutter in bluetooth audio. If you have any fix, please reply.
    2022-01-19T17:15:50+00:00
    Maybe not a solution but at least a workaround.
    I bought a Fancy-Pants BT 5.X PCIE $40 card with Wifi & BT, but immediately noticed audio stutter. I spent hours
    trying to troubleshoot it. A few weeks later I bought a $6 BT 4.0 dongle to check whether it was the card, PC or the headphones that
    caused the problem. The stutter disappeared and I can swear that the overall sound quality is better too, even
    if that's not likely. But I got rid of the stutter with an easy solution which doesn't occupy a card slot! 👍
    I.E. Check BT version compability!
