Bluetooth audio stuttering and lagging
2020-11-27T23:17:25+00:00
This issue has persisted for 5 months now. I am unable to use bluetooth headphones with my Dell XPS 15 9550 because audio and video is constantly interrupted with static. I am able to properly connect and pair my device to the laptop but for example youtube videos lag down and stutter almost like .5x speed. There is a constant interference and so the audio ends up choppy in songs or videos. I have done all troubleshooting with the headphones and audio and bluetooth settings. My Bose QC 35s also are able to connect and function with any other device except my laptop. I suspect it had something to do with a windows update I did over the summer but i am not sure
2020-12-03T19:13:14+00:00
I have the same issue on a Dell Inspiron 7460. It started after the last Windows 10 update in November, Windows 10 version 20H2.  And my headphones are Sony WH-1000XM4.
The headphones always worked very well, now it stuttering and don't stop, becoming terrible to listen to anything.
The suggestions made here did not work.
I found a solution on the web, if you would like to try, but this fix disable the option to use the headphones as headset:
"Press the Windows key and start typing "control panel" to find the icon to open the Control Panel. (As of the time of writing, Windows 10 does not have a way to change this setting via the new 'Settings' interface.)
  1. Find 'Devices and Printers' and double-click it.
  2. Find your paired headphones. The icon may not look like your headphones, but hopefully you should be able to find it.
  3. Right-click the icon and select 'Properties'.
  4. Select the 'Services' tab at the top.
  5. Under 'Bluetooth Services', if 'Hands-free Telephony' is checked, uncheck it.
  6. Click OK.
The audio may cut out as it saves the new settings (you may need to adjust your volumes in the Volume Mixer)"
For me is working fine after I made this change. Hope you find a solution.
67 additional answers
    2021-06-24T21:29:18+00:00
    I had the same problem after a windows update a few days ago. Slow motion and stuttering. Tried uninstalling the bluetooth software in uninstall programs, but then my headphones didn't work at all. The following worked for me. The bluetooth software is still there (Widcomm).
    https://support.kinivo.com/hc/en-us/articles/360062544993
    2021-06-26T16:22:46+00:00
    I had the same problem (Dell XPS13 9350). Here's what worked for me
    1. Go to Control Panel -> Uninstall a Program (in "Programs" category)
    2. Sort by publisher and find the program where publisher is Broadcom. Uninstall that program
    3. Restart the laptop
    Also worked for me after 8 months of no bluetooth audio on my Dell XPS 13
    Thanks!!
    Just wanted to put my 2 cents worth here.
    I am running Windows 10 21H1 Desktop with a TechKey Bluetooth 4.0 dongle.
    After following all the official pathways and failing, I can say that this method worked on my desktop.
    So if you have a desktop PC and having bluetooth skipping issues with Windows 10 - i would suggest to try this method, especially if you are like me and this is week 5 on looking for a solution.
    Good luck and thank you!
    2021-06-30T20:28:13+00:00
    Thanks - this worked for me.
    2021-07-02T21:00:45+00:00
    Same here: issues with any bluetooth headphone after updating to Windows 10 20H2 on Dell XPS13 9350.
    Your tip definitely worked for me and now the audio stuttering problem is solved.
    No actual improvement after hours trying to solve with other instructions above or elsewhere on the web.
    M
