Display driver amdkmdag stopped responding and has successfully recovered.
2020-10-03T00:20:08+00:00
I've been having crash issues for months now with no solution. I've been able to narrow it down to a windows issue but no solution seems to be available.
At random points during gaming (COD Warzone) the video card driver stops working and then immediately recovers. I get a black screen for around 5-10 seconds and that causes my game to crash. It is extremely frustrating.
I have done clean installs of Windows 10 64bit, tested with both NVidia and AMD GPU's, various video card drivers (up to 1 year old), and various other checks and setting changes.
I'm hoping that someone can please respond to help me figure out what is causing this issue because it is extremely frustrating.
Thank you,
Gregg
2021-05-10T14:43:53+00:00
Hey everyone,
I have finally fixed this issue fixed on my PC. I'm so damn happy 😅
Changing my input from DisplayPort to HDMI resolved it. This fixes the crashing completely, even with two sticks of memory in dual-channel mode at full speed 3200Mhz.
This got me curious, since I saw that using HDMI limits my refresh rate to 100Hz. So, I switched back to DisplayPort but forced it to run at 120Hz instead of the full 144Hz. This also runs flawlessly with dual-channel memory and IMO confirms that 144Hz (combined with certain memory configurations) is somehow the causing the crashes.
I've ordered a new DisplayPort cable to see if it resolves the issue at 144Hz, but even if it doesn't I'll be happy with 120Hz since the 5600XT rarely gets above 120 FPS in games I play at 1440p anyway!
I hope this helps some of you.
EDIT: Sorry to hear about your new issue Tyler. I am on the latest Window 10 update and AMD drivers (I now have the full AMD Overlay etc installed) and have not run into that problem.
EDIT 2: New DisplayPort cable has the exact same issue at 144Hz. I can live with 120Hz so it's all good and no more crashes :)
EDIT 3: I other solutions posted online to get 144Hz working. Summary is here: https://evanshortiss.com/amd-driver-memory-lock-timeout
171 additional answers
    2020-12-21T21:20:35+00:00
    I have windows 10 pro and once I updated to 20h2, it all went down hill.
    Games kept acting up, so I tried a driver install. Now I am stuck running my 5700xt
    with Event Device not started (amdkmdap). I am stuck on 20h2. I have to find a fix.
    2020-12-27T23:02:37+00:00
    This is exactly where I am now. Been going around in circles with this since I upgraded in April.
    Ryzen 7 3800x, Red Devil 5700xt, 16GB Corsair LPX Ram
    Crashes is the majority of titles I play. Mainly DX12 titles.
    1. DDU and installed countless 2020 Adrenalin Drivers. All have the same effect, some worse than others.
    2. Bought new case + fans to create an improved airflow
    3. Upgraded Windows to most recent through this time period.
    4. Fresh installs of Windows along the way.
    5. Underclocking, overclocking GPU and VRAM, disabling, enabling XPM.
    6. Setting custom fans curves
    7. Setting different Pagefiles
    8. RMA'd my GPU but it came back fine.
    9. Stress tested CPU, Memory and GPU.
    All lead to the same place, constant crashes in game. I'm on the verge of buying a new PSU althogh I'm sure my 850w can most definately support the system.
    ESENT Errors all the time complaining about databse format. Use to be about Video.UI but since my last windows refresh its been about svchost  and some other Catalog Database.
    2020-12-27T23:32:04+00:00
    Dont bother buying a new psu, already been down that road. It does seem like it could be a power problem causing the GPU to disconnect, but, at least in my experience, I had the exact same problem with a new beastly psu. It did not fix it or change anything.
    2020-12-30T19:26:26+00:00
    I have similar issues in my new build.
    Switched PSU (so don't change yours), motherboard, RAM, cash and a new NVME SSD, only thing left is my CPU (Ryzen 7 2700sx) and Radeon RX 580.
    I opened a RMA for my RX 580 since the driver was always crashing in Overwatch and Fortnite, but when I switched to my old R9 280X, same issue.
    And the latter ran fine in my other computer.
    I also reinstalled Windows, DDU, tried older drivers, stressed test my RAM, underclocked and overclocked my GPU, it's all random; sometimes I can game for 2 hours straight, others I crash in the menus, or after 2-3 minutes.
    Tried graphics at Low, even if I used to run them on High/Ultra back in my old build.
    What scares me is that I was about to purchase an RX 6800 XT or RTX 3080, and I don't know if the problems will persist...
    Question for everyone around here:
    What monitor(s) are you using?
    What size, resolution, refresh rate, connection.
    I have a Dell S3220DGF (32", 1440p, 165hz, connected via Display port)
    and a LG 34WK650-W (34" 2560 x 1080 Ultra wide, 75hz, connected via HDMI because my RX 580 was having problems with 2 Display port monitors back on my older system)
    I have both at 60hz at the moment, but it doesn't change a thing.
    Complement: Both have Freesync, tried having both On, both Off, 1 on the other off, still crashes.
    I've also tried on a single monitor (the LG) using DisplayPort, then HDMI, it still crashes.
    I will reinstall my RX 580 and cancel the RMA, but this needs a fix. I don't know if I must blame Windows, AMD or my MSI motherboard, but I'm out of idea to fix the problem.
    *EDIT*
    I've also found this error at the same time I'm getting a "*Display driver amdkmdag stopped responding and has successfully recovered."*graphics crash:
    "The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID
    {2593F8B9-4EAF-457C-B68A-50F6B8EA6B54}
    and APPID
    {15C20B67-12E7-4BB6-92BB-7AFF07997402}
    to the user DESKTOP-ULJAN3F\**** SID (S-1-5-21-3466181943-1332235542-109778068-1001) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.*"
    I don't know if it's directly linked to the crash, or if it's a result of, but I believe every information could help at this point.
