Display driver amdkmdag stopped responding and has successfully recovered.
2020-10-03T00:20:08+00:00
I've been having crash issues for months now with no solution. I've been able to narrow it down to a windows issue but no solution seems to be available.
At random points during gaming (COD Warzone) the video card driver stops working and then immediately recovers. I get a black screen for around 5-10 seconds and that causes my game to crash. It is extremely frustrating.
I have done clean installs of Windows 10 64bit, tested with both NVidia and AMD GPU's, various video card drivers (up to 1 year old), and various other checks and setting changes.
I'm hoping that someone can please respond to help me figure out what is causing this issue because it is extremely frustrating.
Thank you,
Gregg
2021-05-10T14:43:53+00:00
Hey everyone,
I have finally fixed this issue fixed on my PC. I'm so damn happy 😅
Changing my input from DisplayPort to HDMI resolved it. This fixes the crashing completely, even with two sticks of memory in dual-channel mode at full speed 3200Mhz.
This got me curious, since I saw that using HDMI limits my refresh rate to 100Hz. So, I switched back to DisplayPort but forced it to run at 120Hz instead of the full 144Hz. This also runs flawlessly with dual-channel memory and IMO confirms that 144Hz (combined with certain memory configurations) is somehow the causing the crashes.
I've ordered a new DisplayPort cable to see if it resolves the issue at 144Hz, but even if it doesn't I'll be happy with 120Hz since the 5600XT rarely gets above 120 FPS in games I play at 1440p anyway!
I hope this helps some of you.
EDIT: Sorry to hear about your new issue Tyler. I am on the latest Window 10 update and AMD drivers (I now have the full AMD Overlay etc installed) and have not run into that problem.
EDIT 2: New DisplayPort cable has the exact same issue at 144Hz. I can live with 120Hz so it's all good and no more crashes :)
EDIT 3: I other solutions posted online to get 144Hz working. Summary is here: https://evanshortiss.com/amd-driver-memory-lock-timeout
171 additional answers
    2021-02-04T22:28:14+00:00
    Hi Folks,
    same Problem here, LiveKernelEvent 141 / amdkmdag going **** while playing games (nothing too fancy graphics wise even, just some lol, poe, etc.). I get colorful flicker and artifacts (rainbow dots, funny lines ingame) before the crash, as well as short (~2 seconds) phases of blackscreen a few times before the system shuts down.
    Been through all troubleshooting tips (update drivers, downgrade drivers, update bios, turn fan to max speed, undervolt,...) but nothing seems to help... AMD Software Suite seems to make it worse even, since the app (and all games you start from within the app therefore) crash sooner than any given game started by itself. Plus, no more manual driver selection withouth jumping through a lot of hoops...
    Anyways, my System:
    ASRock B365M Pro4
    Intel i5-9400f
    Radeon RX Vega 56
    I could not reproduce the error with any benchmarks i tried, up until today:
    Valley Benchmark 1.0 causes the crash repeatedly at first/second benchmark run on my machine!
    (directX9 and directX11, Quality set to Ultra)
    Can't help you guys out with a solution sadly, but beeing able to reproduce the error without having to play 2 hours of online matches may help us find the issue faster, so i suggest giving that a try.
    Regards,
    Funkbrother
    2021-02-06T12:48:43+00:00
    Just reporting back in with Far Cry 5 test results. You can see from this screenshot that I had a crash today with Far Cry 5. It took around 15 minutes from booting my PC and starting to play to crash.
    This is after 10 days of no crashes. 5 of those 10 days were with a single 8GB stick of memory. The second 5 were with both of my 8GB sticks and only playing CoD Black Ops Cold War.
    So Far Cry 5 causes a crash for some strange reason. CoD Black Ops Cold War is fine. This is a massive pain in the ****. Apex crashed maybe 4 times in the past few months, so it's pretty rare but can happen.
    2021-02-11T13:26:10+00:00
    I have finally fixed this issue though given everyone's different hardware it won't sort it for everyone.
    From what i gather if you have general crashing outside of games then its probably hardware seating issue or bad windows install.
    For like me where i only have crashing during games what fixed my particular issue and i have no idea why, is downclocking my video card slightly. I have a msi radeon rx 590 armor 8g oc so its overclocked by default. Ryzen 3600, MSI B450 Gaming Pro Carbon Ac mobo, 144hz full HD monitor. Everything is fully updated.
    Downclocked card 100hz in MSI Afterburner and voila, one week later not a single crash whereas I used to have them about every 10 mins in all but the most basic single player games. Obviously this isn't an ideal fix but the most graphics intense stuff I play is Dota 2 at 144hz at highest settings so doesn't create any performance issues for me.
    What's also annoying is when I spoke to MSI the support was awful, like talking to someone with 50 IQ, and they claimed based on the tests they made me do it cannot be a card fault.
    Anyway hope this helps a few people at least. I like you all have tried everything under the sun til this downclock in afterburner i found elsewhere that someone had success with.
    2021-02-19T09:18:03+00:00
    Update - I had no crashes for a week after doing the above steps, but then they started again. It then got even worse to the point where the system would crash in the middle of windows loading, then even during the power up/BIOS phase to the point where I couldn't even see BIOS, although I could see the HD working as if it were booting. I then went though changing up every component in my system one step at a time - swapped the motherboard, ram, cpu, graphics card - eventually found that the graphics card was the culprit. System would boot up fine with my older GT 730 card, but not my newer ASRock RX570 card. The system's been completely stable with the old GT730 card for several weeks now.
    So now I see that it had to have been the graphics card all along, just steadily getting worse over time. I will attempt to get it fixed through ASRock as it is within a year of purchase and will hopefully be fixable under warranty.
