Display driver amdkmdag stopped responding and has successfully recovered.
2020-10-03T00:20:08+00:00
I've been having crash issues for months now with no solution. I've been able to narrow it down to a windows issue but no solution seems to be available.
At random points during gaming (COD Warzone) the video card driver stops working and then immediately recovers. I get a black screen for around 5-10 seconds and that causes my game to crash. It is extremely frustrating.
I have done clean installs of Windows 10 64bit, tested with both NVidia and AMD GPU's, various video card drivers (up to 1 year old), and various other checks and setting changes.
I'm hoping that someone can please respond to help me figure out what is causing this issue because it is extremely frustrating.
Thank you,
Gregg
2021-05-10T14:43:53+00:00
Hey everyone,
I have finally fixed this issue fixed on my PC. I'm so damn happy 😅
Changing my input from DisplayPort to HDMI resolved it. This fixes the crashing completely, even with two sticks of memory in dual-channel mode at full speed 3200Mhz.
This got me curious, since I saw that using HDMI limits my refresh rate to 100Hz. So, I switched back to DisplayPort but forced it to run at 120Hz instead of the full 144Hz. This also runs flawlessly with dual-channel memory and IMO confirms that 144Hz (combined with certain memory configurations) is somehow the causing the crashes.
I've ordered a new DisplayPort cable to see if it resolves the issue at 144Hz, but even if it doesn't I'll be happy with 120Hz since the 5600XT rarely gets above 120 FPS in games I play at 1440p anyway!
I hope this helps some of you.
EDIT: Sorry to hear about your new issue Tyler. I am on the latest Window 10 update and AMD drivers (I now have the full AMD Overlay etc installed) and have not run into that problem.
EDIT 2: New DisplayPort cable has the exact same issue at 144Hz. I can live with 120Hz so it's all good and no more crashes :)
EDIT 3: I other solutions posted online to get 144Hz working. Summary is here: https://evanshortiss.com/amd-driver-memory-lock-timeout
171 additional answers
    2021-01-24T17:44:37+00:00
    As I said, my version of Afterburner was a bit outdated. Maybe it wasn't fully compatible with the latest driver, or something.
    Now I hesitate to install the recent version, but maybe I will give it a try, because it was fine to set the fan curve and see the temperature of GPU in tray.
    2021-01-26T05:24:45+00:00
    I have been having this issue for well over a year, just found this post. Weird thing is it hasnt really forced me to restart my pc until I updated windows about a week ago. I have not installed 20H2 yet, that was my next hope.
    Beginning:
    Core i5-6600k
    Gigabit 1050ti
    ASRock z170 MB
    Crucial 16 gb 2333
    Vampire 750w psu
    MSI 32" 1440p 144hz
    Current:
    Core i5-6600k
    MSI z270 MB
    Asus 5700xt
    Corsair 16 gb 3000
    Vampire 750w psu
    MSI 32" 1440p 144hz
    SO, I havent changed much but curious, has anyone tried using different ports and/or cables on their graphics cards? Im using an amazonbasics displayport cable. Just wondering what everyone is using here.
    2021-01-27T11:40:47+00:00
    Kind of had this show up out of nowhere last month, too. No idea why. sfc / DISM checked for Windows corruption, clean driver install, checked CPU / RAM on compliant stock levels... but this display driver error code 4101 driver timeout stuff keeps arbitrarily happening. No afterburner. In games as well on Desktop or browser usage.
    Hope this can get figured out... >_< I'll try and report it through the integrated AMD bug report tool, too, can't hurt
    2021-01-27T13:31:57+00:00
    I never tried my graphics card in another PCI slot on the motherboard, however I tried both HDMI and Display Port connections, on both my screens, and even 1 screen at a time.
    As I mentioned in a previous post, the only fix I found was changing my USB peripherals setup.
    I have keyboard/mouse plugged up top of my rear pannel, RGB mousepad in the following port a little lower, and my headsed plugged in the front panel.
    I tried 2 different ports behind for my headset and/or RGB mousepad and I was getting crashes, with both my old Radeon RX 580 and my new GeForce RTX 3080 (so no, problem is not AMD exclusive)
    However I haven't tried switching USB around since the latest Windows update release.
