Display driver amdkmdag stopped responding and has successfully recovered.
2020-10-03T00:20:08+00:00
I've been having crash issues for months now with no solution. I've been able to narrow it down to a windows issue but no solution seems to be available.
At random points during gaming (COD Warzone) the video card driver stops working and then immediately recovers. I get a black screen for around 5-10 seconds and that causes my game to crash. It is extremely frustrating.
I have done clean installs of Windows 10 64bit, tested with both NVidia and AMD GPU's, various video card drivers (up to 1 year old), and various other checks and setting changes.
I'm hoping that someone can please respond to help me figure out what is causing this issue because it is extremely frustrating.
Thank you,
Gregg
2021-05-10T14:43:53+00:00
Hey everyone,
I have finally fixed this issue fixed on my PC. I'm so damn happy 😅
Changing my input from DisplayPort to HDMI resolved it. This fixes the crashing completely, even with two sticks of memory in dual-channel mode at full speed 3200Mhz.
This got me curious, since I saw that using HDMI limits my refresh rate to 100Hz. So, I switched back to DisplayPort but forced it to run at 120Hz instead of the full 144Hz. This also runs flawlessly with dual-channel memory and IMO confirms that 144Hz (combined with certain memory configurations) is somehow the causing the crashes.
I've ordered a new DisplayPort cable to see if it resolves the issue at 144Hz, but even if it doesn't I'll be happy with 120Hz since the 5600XT rarely gets above 120 FPS in games I play at 1440p anyway!
I hope this helps some of you.
EDIT: Sorry to hear about your new issue Tyler. I am on the latest Window 10 update and AMD drivers (I now have the full AMD Overlay etc installed) and have not run into that problem.
EDIT 2: New DisplayPort cable has the exact same issue at 144Hz. I can live with 120Hz so it's all good and no more crashes :)
EDIT 3: I other solutions posted online to get 144Hz working. Summary is here: https://evanshortiss.com/amd-driver-memory-lock-timeout
171 additional answers
    2020-10-03T15:36:02+00:00
    Not sure what else I can offer. I'll open up the question for others to comment.
    2020-10-03T23:23:29+00:00
    ok well thanks for trying to help
    2020-10-04T00:03:13+00:00
    I have tried playing another game: Rainbow Six: Seige and it is also crashing.
    The warning in the event viewer is still: Display driver amdkmdag stopped responding and has successfully recovered.
    I have also tried with NVidia card and the warning is the same except instead of amd it says nvd
    Please help!
    Gregg
  4. Igor Leyko 112.2K Reputation points Independent Advisor
    2020-10-05T20:08:16+00:00
    Hi Gregg,
    I'm Independent Advisor not Microsoft employee or support person. But I'm in contact with Windows developers since 1995 - as a one of the best Windows beta-testers till 2009 when program was closed, as an MVP in 2005-2017 including Windows System & Performance nomination. So I have deep enough Windows knowledge and you may trust me. It's a pleasure for me to help others and I'll do all my best to help you.
    Did you try to clean GPU cooling system (or laptop internal cooling system) from dust?
