Display driver amdkmdag stopped responding and has successfully recovered.
2020-10-03T00:20:08+00:00
I've been having crash issues for months now with no solution. I've been able to narrow it down to a windows issue but no solution seems to be available.
At random points during gaming (COD Warzone) the video card driver stops working and then immediately recovers. I get a black screen for around 5-10 seconds and that causes my game to crash. It is extremely frustrating.
I have done clean installs of Windows 10 64bit, tested with both NVidia and AMD GPU's, various video card drivers (up to 1 year old), and various other checks and setting changes.
I'm hoping that someone can please respond to help me figure out what is causing this issue because it is extremely frustrating.
Thank you,
Gregg
2021-05-10T14:43:53+00:00
Hey everyone,
I have finally fixed this issue fixed on my PC. I'm so damn happy 😅
Changing my input from DisplayPort to HDMI resolved it. This fixes the crashing completely, even with two sticks of memory in dual-channel mode at full speed 3200Mhz.
This got me curious, since I saw that using HDMI limits my refresh rate to 100Hz. So, I switched back to DisplayPort but forced it to run at 120Hz instead of the full 144Hz. This also runs flawlessly with dual-channel memory and IMO confirms that 144Hz (combined with certain memory configurations) is somehow the causing the crashes.
I've ordered a new DisplayPort cable to see if it resolves the issue at 144Hz, but even if it doesn't I'll be happy with 120Hz since the 5600XT rarely gets above 120 FPS in games I play at 1440p anyway!
I hope this helps some of you.
EDIT: Sorry to hear about your new issue Tyler. I am on the latest Window 10 update and AMD drivers (I now have the full AMD Overlay etc installed) and have not run into that problem.
EDIT 2: New DisplayPort cable has the exact same issue at 144Hz. I can live with 120Hz so it's all good and no more crashes :)
EDIT 3: I other solutions posted online to get 144Hz working. Summary is here: https://evanshortiss.com/amd-driver-memory-lock-timeout
171 additional answers
    2021-01-04T09:45:55+00:00
    I had the same experience prior to the latest drivers, just one crash a day. I'd play for a few minutes, the system would lock up and I'd need to reset, or it would reboot itself within a minute.
    Since updating to the latest drivers I usually crash to the desktop instead. Sometimes I get a second crash these days though, and it might not happen within the first 15 minutes.
    2021-01-05T23:08:57+00:00
    Maybe we're onto something. I unplugged all USB devices:
    • USB Hub
    • Flight Stick
    • Logitech Headset
    • Mouse (was in the hub)
    • Keyboard (was in the hub)
    Next, I plugged my only mouse and keyboard into the back of the PC - nothing else, not even the USB hub.
    I've played just fine these past two nights. No crashes in Apex or The Witcher, even after waking the PC from sleep mode.
    Another thing I've done via the Radeon software is limit the GPU frequency to 1700Mhz and increased the Power Limit by 15%.
    I'll stick with this for a while and see if it remains a success, then start plugging devices back in too.
    2021-01-05T23:26:14+00:00
    Glad to hear!
    I haven't played with my overclock setting besides augmenting fan speed to avoid overheating (at first I thought it was a heat issue)
    I still haven't plugged any other USB accessories, however I'm now at day 4 since the format and last crash.
    I really think we're zeroing in the source (or partial source) of the problem.
    Too many usb gadgets seems to be part of the problem, and maybe display resolution/frequency as well.
    If we can eventually confirm that, we'll then have to figure out what's at fault: Windows or the motherboard
    Maybe all our boards use the same usb chipset and it's at fault.
    Well, I'm glad we're getting closer to a cause, but we're far from a solution other than "Don't replug your USB accessories..."
    2021-01-06T17:29:38+00:00
    I have the same exact problem here. I actually recently bought this computer two weeks ago from bestbuy (cyberpower)
    -Specs-
    CPU- AMD Ryzen 7 3700X
    RAM- 16GB
    GPU- AMD Radeon 5700xt
       It usually crashes when gaming between 5 to 15min. My screen goes black and I loose audio from my whole computer which then I have no other choice but to restart.
       The weird thing is tho that It never happens again after I restart my computer (until I go to bed and come back the next morning)
    I have an LG ultrawide monitor 2560x1080 75hz
    I was reading and saw that maybe it could be narrowed down by peripherals idk..
    Already tried all the driver uninstalls and re-installs and the issue still persists.
    I have the exact same problem but with 5600 xt. Also 4101 in Event Viewer, so perhaps if you checked it out, i think you'd find the same error there. You say that you bought your pc two weeks ago, and that issue appeared on my pc around three weeks ago after updating Windows, so unless something in my pc broke on that day, i guess that's an issue with Windows? Especially since it disappears after rebooting.
