Display driver amdkmdag stopped responding and has successfully recovered.
2020-10-03T00:20:08+00:00
I've been having crash issues for months now with no solution. I've been able to narrow it down to a windows issue but no solution seems to be available.
At random points during gaming (COD Warzone) the video card driver stops working and then immediately recovers. I get a black screen for around 5-10 seconds and that causes my game to crash. It is extremely frustrating.
I have done clean installs of Windows 10 64bit, tested with both NVidia and AMD GPU's, various video card drivers (up to 1 year old), and various other checks and setting changes.
I'm hoping that someone can please respond to help me figure out what is causing this issue because it is extremely frustrating.
Thank you,
Gregg
2021-05-10T14:43:53+00:00
Hey everyone,
I have finally fixed this issue fixed on my PC. I'm so damn happy 😅
Changing my input from DisplayPort to HDMI resolved it. This fixes the crashing completely, even with two sticks of memory in dual-channel mode at full speed 3200Mhz.
This got me curious, since I saw that using HDMI limits my refresh rate to 100Hz. So, I switched back to DisplayPort but forced it to run at 120Hz instead of the full 144Hz. This also runs flawlessly with dual-channel memory and IMO confirms that 144Hz (combined with certain memory configurations) is somehow the causing the crashes.
I've ordered a new DisplayPort cable to see if it resolves the issue at 144Hz, but even if it doesn't I'll be happy with 120Hz since the 5600XT rarely gets above 120 FPS in games I play at 1440p anyway!
I hope this helps some of you.
EDIT: Sorry to hear about your new issue Tyler. I am on the latest Window 10 update and AMD drivers (I now have the full AMD Overlay etc installed) and have not run into that problem.
EDIT 2: New DisplayPort cable has the exact same issue at 144Hz. I can live with 120Hz so it's all good and no more crashes :)
EDIT 3: I other solutions posted online to get 144Hz working. Summary is here: https://evanshortiss.com/amd-driver-memory-lock-timeout
171 additional answers
    2021-01-03T14:02:35+00:00
    I tried this driver install method once, but it didn't resolve anything for me. Fingers crossed for you.
    2021-01-03T14:08:26+00:00
    Same, this method never worked for me, just meant I had to use 3rd party software to control the fan curves.
    I get better stability on this monitor: https://www.lg.com/ca_en/desktop-monitors/lg-E2242T
    Than I do on this one: Iiyama Prolite XB2779QS
    Seems like the more the card is stressed the worse it gets with some games. However benchmark software doesn't give me any issues.
    2021-01-03T14:08:53+00:00
    I had error logs related with the Corsair CUE Service in the past, but they weren't the cause of any crashes. I haven''t reinstalled the Corsair software with this fresh Windows 10 install.
    One thing I have noticed is that whenever my system reboots after a crash I have a log like this:
    A problem has occurred with one or more user-mode drivers and the hosting process has been terminated.  This may temporarily interrupt your ability to access the devices.
    Also, this one:
    The device HID-compliant headset (location (unknown)) is offline due to a user-mode driver crash.  Windows will attempt to restart the device 5 more times.  Please contact the device manufacturer for more information about this problem.
    This is rare now since it's mostly the timeout error these days, but could potentially be related to the Logitech headset I have?
    2021-01-03T15:06:44+00:00
    I've managed to recreate it using the AIDA64 Extreme GPGPU benchmark. It generated some crazy errors funny enough. It may have been because the driver has crashed earlier in FS 2020.
