Display driver amdkmdag stopped responding and has successfully recovered.
2020-10-03T00:20:08+00:00
I've been having crash issues for months now with no solution. I've been able to narrow it down to a windows issue but no solution seems to be available.
At random points during gaming (COD Warzone) the video card driver stops working and then immediately recovers. I get a black screen for around 5-10 seconds and that causes my game to crash. It is extremely frustrating.
I have done clean installs of Windows 10 64bit, tested with both NVidia and AMD GPU's, various video card drivers (up to 1 year old), and various other checks and setting changes.
I'm hoping that someone can please respond to help me figure out what is causing this issue because it is extremely frustrating.
Thank you,
Gregg
2021-05-10T14:43:53+00:00
Hey everyone,
I have finally fixed this issue fixed on my PC. I'm so damn happy 😅
Changing my input from DisplayPort to HDMI resolved it. This fixes the crashing completely, even with two sticks of memory in dual-channel mode at full speed 3200Mhz.
This got me curious, since I saw that using HDMI limits my refresh rate to 100Hz. So, I switched back to DisplayPort but forced it to run at 120Hz instead of the full 144Hz. This also runs flawlessly with dual-channel memory and IMO confirms that 144Hz (combined with certain memory configurations) is somehow the causing the crashes.
I've ordered a new DisplayPort cable to see if it resolves the issue at 144Hz, but even if it doesn't I'll be happy with 120Hz since the 5600XT rarely gets above 120 FPS in games I play at 1440p anyway!
I hope this helps some of you.
EDIT: Sorry to hear about your new issue Tyler. I am on the latest Window 10 update and AMD drivers (I now have the full AMD Overlay etc installed) and have not run into that problem.
EDIT 2: New DisplayPort cable has the exact same issue at 144Hz. I can live with 120Hz so it's all good and no more crashes :)
EDIT 3: I other solutions posted online to get 144Hz working. Summary is here: https://evanshortiss.com/amd-driver-memory-lock-timeout
171 additional answers
    2021-01-03T01:25:32+00:00
    Ive got Cooler Master equipment including a RGB mousepad.
    Also headset then obvious keyboard and mouse. Ive disconnected the mousepad and rbg heaphone holder and it didnt crash for 3 hours last night. Ill try again tonight.
    2021-01-03T01:27:21+00:00
    Are you getting black screen with audio then the app crashes taking you back to the desktop?
    Check event logger for the error and see if it matches with ours too
    Your another with high refresh rate but not 1440p. Do you have any gaming peripherals like a rgb mousepad or anything that also hooks up?
  3. Don Varnau 19,930 Reputation points Volunteer Moderator
    2021-01-03T02:36:33+00:00
    [snip]
    @ GreggVertes
    On the original post, first post on this page,
    Display driver amdkmdag stopped responding and has successfully recovered. click on Subscribe then Unsubscribe..
    Don
    2021-01-03T13:01:45+00:00
    I might have had a breakthrough at least for AMD users. I did a clean uninstall of the graphics drivers then followed the instructions on this vid to install the drivers without the AMD radeon software, as normally you don't get a choice  (1) How to install AMD Drivers (without the installing Adrenaline Software) - YouTube
    Not sure whether doing the same with nvidia software will work, i know at least you guys get the choice to install drivers without the software.
    Haven't had a crash yet since although its only been one day so will update if it starts crashing again
    I would not consider this an acceptable solution as I like using the features of the radeon software. So many people are reporting these issues for months going back many software versions, can't believe the parties involved haven't got together and sorted it.
