SCEP Certificate enrollment initialization for local system
2023-02-02T21:32:59+00:00
i have been getting random reboots with the error about SCEP.
SCEP Certificate enrollment initialization for Lokaal systeem via https://AMD-KeyId-907d65e9b562315997dd5ad086b2b7598957b92c.microsoftaik.azure.net/templates/Aik/scep failed:
GetCACaps
GetCACaps: Not Found
{"Message":"The authority "amd-keyid-907d65e9b562315997dd5ad086b2b7598957b92c.microsoftaik.azure.net" does not exist."}
HTTP/1.1 404 Not Found
Date: Thu, 02 Feb 2023 21:11:31 GMT
Content-Length: 121
Content-Type: application/json; charset=utf-8
X-Content-Type-Options: nosniff
Strict-Transport-Security: max-age=31536000;includeSubDomains
x-ms-request-id: de2906fa-254f-44ed-9158-1f8af38d8f71
Method: GET(296ms)
Stage: GetCACaps
Niet gevonden (404). 0x80190194 (-2145844844 HTTP_E_STATUS_NOT_FOUND)
    2023-04-19T07:47:59+00:00
    Apologies if came across as personal, not meant to.
    I am suffering from the same frustrations that plenty of other users are.
    No worries though, I've already rebuilt from the ground up twice because of similar issues.
    for now, my solution is power it down and worry about it later.
    Lost the personal-drive to actually get it working again now, only to risk it occuring again.
    2023-04-19T09:41:20+00:00
    No probs the offer of help is still there if you need it. I can't guarantee we can fix it between us but having someone with 47 years of experience around to help you can make a difference.
    2023-04-29T07:46:59+00:00
    bro i got a cpu form 2 years ago man
    2023-04-29T11:14:12+00:00
    What you’re seeing is AMD setting up their server wrong. You would get the same error if your router was messed up.
    It’s NOT causing crashes, it’s being logged AFTER the crash - when the system reboots.
    If you don’t believe me, go to the server address, you’ll get a missing file. And Feel free to browse AMD’s forums and find the post where a employee stopped by and confirmed the server issue.
    2023-04-29T15:42:36+00:00
    I saw the same message , I also saw another user state exactly the same thing I did I put a discrete TPM in and the messages seem to have gone away, I don't know why they just have. It's not like the address they were going to has magically changed - as far as I am aware it's still the same - you go to it and it says something about a missing style sheet or some such. I just haven't seen one of those messages in a while. I would also think if it was a misconfigured server - after all this time they would have fixed it.
