“Your credentials could not be verified” when entering PIN. Help!!
2023-03-05T06:21:58+00:00
I restarted my computer and when i went to put in my pin i got the message “your credentials could not be verified”. I tried to click “I forgot my pin” but when it did I got “Something went wrong and your PIN isn't available (status: Oxc000006d, substatus:
Oxc0070070). Click to set up your PIN again.” and when I did that I get the message “The user profile service service failed the sign in. user profile cannot be loaded”. So I looked around and safe mode just wouldn’t work then i decided to reset my pc and keep all files. now when I hold shift and click the power button i only have the option to turn off my PC. I’m really frustrated and would just like to use my computer.
    2023-06-04T10:19:57+00:00
    Hi no did not work .thanks
    2023-10-26T01:19:03+00:00
    I've tried restarting my computer in the way specified with safe mode networking and all that but my computer still says Credentials could not be verified. Why is it not working?
    2023-11-30T09:56:12+00:00
    Greetings I also have the same problem but with me I cannot do anything because every fixture in trouble shooting requires me to put a password I cannot even reset the pc
    2023-12-14T07:34:23+00:00
    It works but after shutting down, when start my laptop again the problem arises please suggest a permanent solution to this problem
    Thanking You
    2023-12-19T15:57:07+00:00
    If you got that fixed can you pls help me as well... I got the same problem
