Screen stuck on "Updates are underway. Please keep your computer on."
Reported
2023-03-23T00:54:46+00:00
I really need to fix this problem. I tried using the troubleshooter before restarting but that was stuck too. It said I had to reboot first. How can I fix this issue without destroying or corrupting any important Windows components?
2023-03-23T01:36:00+00:00
Good day! I'm Raniel. I understand your frustration regarding this issue and I'll do my best to help.
If it is still stuck on that screen, perform a hard shutdown (press and hold the power button for 5-10 seconds until it turns off), disconnect your peripherals, unplug/replug your power cable and turn it back on and see if the updates will install or rollback.
Kindly perform a reset of your windows update components using this reset script (ensure that you are running the command prompt as an administrator). Please refer to this article: https://www.elevenforum.com/t/reset-windows-upd...
Once done, reboot the machine and reinstall the updates.
I also suggest that you refer to the steps on these articles to further troubleshoot the issue:
https://support.microsoft.com/windows/troublesh...
https://support.microsoft.com/windows/get-help-...
I hope this helps. Good luck!
________________________________________________________
41 additional answers
    2024-05-11T13:30:20+00:00
    Go back to windows 10 windows 11 isn't right just like Vista was a complete headache for many.
    2024-06-02T12:40:25+00:00
    Please let me know the phenomenon Please let me know if this phenomenon is dangerous. If so, please tell me how to solve it.
    2024-06-08T18:33:12+00:00
    My screen has been stucked for more than 1 hrs
    Please help me
    2024-06-22T18:18:57+00:00
    Hello user!
    Please note that the "Updates are underway" screen indicates that there is an update ongoing, or a pending install update... Please try to wait for as long as u can and make sure your computer is on a stable nonmetered internet connection.
    You should try to minimize using the hard power off button because if you do and you reboot the computer, as long as the update didn't finish it would sometime try to install again showing that, so let it install once and for all...
    I'll like to hear your feedback on any issues experienced
