Screen stuck on "Updates are underway. Please keep your computer on."
Reported
2023-03-23T00:54:46+00:00
I really need to fix this problem. I tried using the troubleshooter before restarting but that was stuck too. It said I had to reboot first. How can I fix this issue without destroying or corrupting any important Windows components?
2023-03-23T01:36:00+00:00
Good day! I'm Raniel. I understand your frustration regarding this issue and I'll do my best to help.
If it is still stuck on that screen, perform a hard shutdown (press and hold the power button for 5-10 seconds until it turns off), disconnect your peripherals, unplug/replug your power cable and turn it back on and see if the updates will install or rollback.
Kindly perform a reset of your windows update components using this reset script (ensure that you are running the command prompt as an administrator). Please refer to this article: https://www.elevenforum.com/t/reset-windows-upd...
Once done, reboot the machine and reinstall the updates.
I also suggest that you refer to the steps on these articles to further troubleshoot the issue:
https://support.microsoft.com/windows/troublesh...
https://support.microsoft.com/windows/get-help-...
I hope this helps. Good luck!
________________________________________________________
41 additional answers
    2025-01-18T08:36:54+00:00
    what will i do if my computer is already stuck on updates
